06-21-2022, 01:39 PM | #1 |
Battery cable switch for 46 Ford
I curently have the stock set up with braided cable for positive ground. I would like to get the shutoff switch but put it on the negative cable which go's to solenoid but everything I find is for the positive terminal which would prob be too large. I am happy with braided metal pos cable.
Can I clamp ohe of these switches tight enough on the negative terminal to have a good circuit? Any advice is appreciated,thanks |
06-21-2022, 07:11 PM | #2 | |
Re: Battery cable switch for 46 Ford
06-21-2022, 07:59 PM | #3 |
Never heard of Cole Hersee but I agree with having the cut off switch within easy reach of the driver. If you need it in a hurry, lifting the battery cover will take too long especially since you guys would have to exit the car and dodge the steering wheel.
06-22-2022, 05:17 AM | #4 |
Would the V8 Forum guys have an opinion?
06-22-2022, 06:04 AM | #5 |
Are you talking about one of those disconnects that clamps to the battery post ? If so, forget about it. [smiley face]
As mentioned, install a good high amp marine type switch within easy reach. Its best in the ground line, but, will work on either. |
06-22-2022, 07:18 AM | #6 |
Can you fix the battery drain issue? |
06-22-2022, 09:35 AM | #7 |
Putting the battery disconnect in line w/the ground cable is usually considered the prudent way to do it. Some people disagree and support putting it inline w/the ungrounded cable.
06-22-2022, 10:09 AM | #8 | |
Is there a draw issue ? Hmm, didn't know that. But in that case, the draw should be fixed. |
06-22-2022, 10:15 AM | #9 |
I've read of lots of horror stories about the battery post mounted disconnects. I've used them on various vehicles over the years and never had a problem w/them.
06-22-2022, 12:54 PM | #10 | |
And if always used correctly could be fine forever, almost. But they are hard to get at, I think. And I think some leave the contact loose which leads to the problems. JMHO. |
06-23-2022, 09:49 AM | #11 |
Hard to get at on a Model A unless the floor boards are modified, but not so hard on a '46 Ford, just open the hood and it's right there on the RH side of the firewall.
