06-06-2022, 10:09 AM | #1 |
WD40 as hand cleaner
Wondering if I am the only one that uses WD40 for cleaning the grease off my hands?
06-06-2022, 10:11 AM | #2 |
Re: WD40 as hand cleaner
The only one that I know of -----------
06-06-2022, 10:21 AM | #3 |
I use sawdust, then soap and water.
06-06-2022, 10:40 AM | #4 |
Go-jo or such
Then lava soap I think wd-40 stinks and stays with you I’ve also started using rubber gloves alot especially when into parts cleaners |
06-06-2022, 10:50 AM | #5 |
I use borax and dish washing soap.
BTW, WD-40 makes a good under arm deodorant too! :-) |
06-06-2022, 11:01 AM | #6 |
Ruth "Sometimes you really DO need to read the whole thread" |
06-06-2022, 11:03 AM | #7 |
I use dish washing liquid and a worn out scotch brite pad.
06-06-2022, 11:03 AM | #8 |
06-06-2022, 11:10 AM | #9 |
I’ve used wd-40 for cleaning greasy hands, it also helps arthritic hands! Mostly use it for cleaning bugs and tar off of paint
06-06-2022, 11:59 AM | #10 |
This:
Making the simple complicated for over 30 years. |
06-06-2022, 01:04 PM | #11 |
I think that Dawn dish soap and warm water is easiest on your hands and is inexpensive , works very well especially with a small brush. Gojo is good but if you tend to use water to remove it and the dirt rather than a paper towel or a rag, sooner or later you will be needing to clean your drain as it can gum up the drainage path.
06-06-2022, 01:10 PM | #12 |
Dawn dish soap & a scrub brush works for me.
06-06-2022, 01:28 PM | #13 |
I like Tub o’Towels. Great for removing oil/grease/dirt from hands and other objects without water. I do use WD40 as a solvent when cleaning machine parts that the water-based parts cleaners struggle with.
06-06-2022, 01:34 PM | #14 |
Boraxo! Keep them mule teams moving!
06-06-2022, 01:46 PM | #15 |
I have never used WD-40 BUT automatic transmission fluid works well for the worst oily grime that I have gotten into. Then clean with hand cleaner.
BTW, penetrating oils like PJ Blaster do a good job of cutting into the grime on parts before cleaning with something else. I suppose WD-40 would be similar to this. |
06-06-2022, 01:54 PM | #16 | |
eog
1928 closed cab pickup. All black, no bling or add-on shiny stuff. Just a simple working man's truck. |
06-06-2022, 02:18 PM | #17 |
06-06-2022, 03:07 PM | #18 |
I buy it by the gallon. Hand cleaner- yes! Tar remover-yes. Pentrating oil-yes. Displaces moisture and leaves a protective film.
06-06-2022, 03:21 PM | #19 |
“BTW, penetrating oils like PJ Blaster do a good job of cutting into the grime on parts before cleaning with something else. I suppose WD-40 would be similar to this.”
I use Eazy Off oven cleaner a lot Especially on things like latches and regulators Spray on put in the sun, wash off in 30 minutes or so. |
06-06-2022, 04:29 PM | #20 |
If WD40 does what it is supposed to do, displace water, what is it doing to the moisture in your skin?
