04-30-2022, 11:25 AM | #1 |
Front Disc Brakes
Does anybody make a front disc kit (Hydraulic of course) that fits stock Model A spindles? Thanks
04-30-2022, 01:23 PM | #2 |
Re: Front Disc Brakes
They should be at the hot-rod vendors.
04-30-2022, 02:17 PM | #3 |
There are no brackets for the early spindles that I'm aware of, they are made for the larger '37-'48 bolt pattern.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
05-01-2022, 01:46 PM | #4 |
As I am beginning to understand it I would first need to switch to the 37-48 spindles and then get a disc brake kit to go with them? Would i be able to maintain the 5 x 5 1/2 bolt pattern?
05-01-2022, 05:22 PM | #5 |
In my opinion a better solution would be to design and make brackets to fit the disk brakes to the Model A spindle. Not everyone can do this. The way to go about it is to buy the parts then design the brackets. It may take making a new disk or modifying the disks that are available, or maybe an adapter. Look at Wilwood racing calipers and disks. Someone did this for the Model T after a friend of his died because of failed brakes.
Start here: https://www.wilwood.com/BrakeKits/Br...+A&option=Base The Model T brakes can be seen here: https://www.modeltford.com/item/2565.aspx That may be a good place to start.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-01-2022 at 05:33 PM. |
05-01-2022, 06:56 PM | #6 |
A wire wheels need the support of the drum edges... |
05-01-2022, 09:32 PM | #7 |
Mike Hoskins makes a well-engineered set of disc brakes for Model A's, called Hoss Brakes. He has a set on his '31 coupe and has gone into production. He has his rotors cast and I can't tell you for sure how the rest is done, but they're ingenious. His phone number is 816 352 7097. Tell him Jim Speedster sent you.
05-02-2022, 09:55 AM | #8 |
I will do that, Thanks!
05-02-2022, 12:35 PM | #9 |
After I got the spindles and hubs modified to later model I used a Wilwood kit that bolted on with no additional mods.
05-09-2022, 07:54 PM | #10 | |
05-09-2022, 07:58 PM | #11 | |
05-09-2022, 08:45 PM | #12 |
A friend put disc brakes on the front of his Model A. The brake dust ended up all over the wire wheels and he regretted doing it.
Charlie Stephens |
05-11-2022, 01:22 AM | #13 |
I've had a couple great conversations with Mike and seen some pictures. His set ups look and sound really good and I'll be seriously looking at it when he has the parts and the kits assembled.
