04-20-2022, 11:25 AM | #1 |
56 door hinge torque?
Anyone know what the torque is for the hinge to frame and hinge to door is? Cannot seem to find it anywhere if there even was a torque reading for it. Also would you use blue locktite on the bolts? Thanks
04-20-2022, 03:36 PM | #2 |
Re: 56 door hinge torque?
There is no need to use locktite on any of the original body bolts having the nubbed washer-heads, or the normal hex-heads with nubbed or serrated washers. Total overkill. These bolts will not back out without force.
I have always used a 1/4" drive socket set to torque the door hinge bolts down. The socket wrench handle is only 5 inches long. You can get the bolts plenty tight using a 1/4 inch drive socket without the need for any torque wrench. They've never loosened up. Last edited by Daves55Sedan; 04-22-2022 at 12:06 AM. |
04-20-2022, 05:28 PM | #3 |
1/8" sockets? Smallest I have are 1/4".
04-20-2022, 07:15 PM | #4 |
I think Dave means 3/8" DRIVE.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
04-20-2022, 07:36 PM | #5 |
Google torque specs to find the specs on different size bolts and use that as a guide for the size bolts you have..
04-22-2022, 12:06 AM | #6 |
For removal of any stubborn bolts, I use a socket drive set one size larger than the bolt thread diameter, but for installation of new or clean used bolts and nuts, I use one size smaller. So, for a 5/16" thread, 1/4 inch drive is what I use. |
04-22-2022, 10:43 AM | #7 |
It's 15lbs for both sides per Shop Manual.
