04-13-2022, 06:33 PM | #1 |
Quick fix axle seal
I know this is not the proper fix but pulling the rear end apart is just not an option for me right now. Other projects call and it is spring. I found an old thread with a number for a seal and cross referenced it to this National number. It fit nice and I think it will do the job until next winter when I`ll do the inner axle seals. I could have put two seals on each side. Here are some pictures. Hope this may help someone. thumbnail_image0 (1).jpg
Tommy |
04-13-2022, 08:32 PM | #2 |
Re: Quick fix axle seal
Please post the seal number.
Thanks, Karl |
04-13-2022, 09:53 PM | #3 |
It is on the box in the picture. National 340835
Tommy |
05-28-2022, 11:14 AM | #4 |
I just did some measuring and while these may fit the axle housings shown, I do not think they will fit the Pilot/35/36 type housings. The spec for the seal shows an OD of 1.375".
the bore of my Pilot casings are 1.327. I have ordered some and they are on their way. I don't think they will work for me. I should have measured before ordering. Can anyone confirm the 40 type axles casings have a bore of 1.375"? or is the axle in the above photo a one-off? Mart. |
06-03-2022, 01:25 AM | #5 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Ford Pilot inner rear brake drum/grease retainer oil seal dimensions: 1.140 IDX 1.832 ODX .453 FORD part number: B4245,
Outer rear brake drum grease retainer ,oil seal dimensions: ID 2.062X 3.194 ODX .453, FORD part number: B-1175A |
06-04-2022, 12:47 AM | #6 |
41 Ford Deluxe 29 Model A 56 DeSoto Firedome |
06-05-2022, 08:48 AM | #7 |
I have put 500 miles on the car with the national seals installed. Working great.
Tommy |
