02-27-2022, 10:44 PM | #1 |
36 oil pressure gauge test.
How do I check electrically a 36 oil pressure gauge to see if it is working?
02-28-2022, 04:39 AM | #2 |
Re: 36 oil pressure gauge test.
You only need to touch the wires on the batt terminals momentarily to see if the needle moves.I usually do only 1 cycle .When needle reaches the top(F) then remove the wire. Last edited by deuce lover; 02-28-2022 at 04:46 AM. |
