01-01-2022, 08:16 PM | #1 |
Temp sensor port thread chaser
Been searching the inter webs for a thread chaser or thread restorer for 59a temp sensor ports on the heads. Can’t seem to find one in 3/8 in-18 thread pitch. Anyone have any leads on where i can buy one?
01-01-2022, 08:24 PM | #2 |
Re: Temp sensor port thread chaser
Try a pipe thread. Be careful not to go too deep, they are tapered.
01-01-2022, 08:43 PM | #3 |
try 3/8 npt
01-01-2022, 11:38 PM | #4 |
3/8 npt
01-02-2022, 12:26 AM | #5 |
Disclaimer; I am not 100% intimate with late model flatheads....
However...are you sure its NPT [National Pipe Taper]? I thought it was NPP [National Pipe parallel]. I thought the female thread [in the head] was parallel, and the male thread [the temp probe] is tapered, so that the more you tighten it up, the tighter it gets, thus sealing.
01-02-2022, 03:30 AM | #6 | |
Believe me, the MALE tapered thread WILL get tighter, the deeper it goes into a FEMALE tapered thread. DD |
01-02-2022, 04:05 AM | #7 |
The port in the head is NPT.National Pipe Taper.Brian was correct.
01-02-2022, 10:10 AM | #8 |
Thanks for all the info but where do I get one?
01-02-2022, 10:13 AM | #9 |
Here is one of many on EBAY or your local Ace Hdwe.
https://www.ebay.com/itm/31342088801...EAAOSwvypgK1VR |
01-02-2022, 10:25 AM | #10 |
Make sure the tap is made of HSS (High Speed Steel) not HC (High Carbon)
01-02-2022, 10:52 AM | #11 |
When I needed one for my 8ba I bought a set at Harbor Freight for cheap. May not be the highest quality but chased the threads on the head no problem.
https://www.harborfreight.com/6-piec...set-91395.html
Making the simple complicated for over 30 years. |
01-02-2022, 11:12 AM | #12 |
got it. thanks gentlemen. added to my list of things to buy.
01-02-2022, 11:23 AM | #13 |
so next question on engine ports, on each side of the block behind water pumps there are threaded ports for either threaded plug (like on my other bare block) or drain pet cocks for the water jackets. Should I plug them or use pet cocks? what size are those threads normally?
01-02-2022, 11:27 AM | #14 |
Yes, but if you tap the tapered female thread TOO deep, the hex on the male nipple will bottom out, preventing the threads from forming a seal
01-02-2022, 12:12 PM | #15 | |
01-02-2022, 12:17 PM | #16 |
01-02-2022, 12:26 PM | #17 |
thanks again gentlemen.
01-02-2022, 01:00 PM | #18 |
I would use drain cocks.
01-02-2022, 01:29 PM | #19 |
Me too. Ford installed drain cocks in the block.
01-02-2022, 02:56 PM | #20 |
