12-10-2021, 06:07 PM | #1 |
I'm going to try to repair this fender
1ST I'm going to hammer it back into relative shape Maybe a wire along the edge...then try to stich the tear....nothing to lose and knowledge to gain.
12-10-2021, 06:13 PM | #2 |
Re: I'm going to try to repair this fender
It never hurts to give something a try. That is how we learn.
Vic |
12-10-2021, 06:17 PM | #3 |
I can share the knowledge I'd gained through the years when handed something akin to this to finish. If a replacement is available, purchase it.
12-10-2021, 06:20 PM | #4 |
Kube,I'm learning metal work as I go...I do think I'm going to source a new fender down the road.Its amazing how beat up this fender is
12-10-2021, 06:44 PM | #5 |
12-10-2021, 07:05 PM | #6 | |
A good one to learn on for certain.
12-10-2021, 07:30 PM | #7 |
MSmelcer40: while I quite agree with and respect Kube, that fender is repairable and a perfect platform upon which to learn basic metal repairing and finishing. May I suggest your proposal for repair sequence is proper and you would be well~served to review a few uTube videos explaining metal propensities and working. Go for it, take your time and publish the results!
WARM REGARDS, MARCUS |
12-10-2021, 07:35 PM | #8 |
It might be worth investing in one of these, wish I had, it would have saved lots of hours and pounds of bondo.
Steve in Denver |
12-10-2021, 07:44 PM | #9 |
12-10-2021, 07:58 PM | #10 |
If you are going to try straightening, use a wooden slapper (hammer). Much more effective than even a body hammer, plus will keep stretching down to a minimum.
12-10-2021, 08:00 PM | #11 |
I love Harbor Frieght....there's one 2 streets over from where I live
12-10-2021, 08:02 PM | #12 |
I've contacted Eastwood and they have a set of hammers and a slapping file ....you say wooden?
12-10-2021, 08:11 PM | #13 |
Frequently it is best to have a fender bolted in place when working on it. May not fit if tried later. Newc
12-10-2021, 08:21 PM | #14 |
I've seen where they make a jig that replicates the bedside from a piece of plywood....I still will leave it bolted to the truck.....my plan is to resist completely disassembling the truck until I get it running and driving.then while waiting for the Engine rebuild I will do some bodywork.
12-10-2021, 08:34 PM | #15 |
If you do decide to repair that fender, PLEASE do not put a metal rod pr piece of wire in it. That is not nice to put it mildly. Repair it properly.
12-10-2021, 08:54 PM | #16 |
Is it Taboo or something to put a price of 3/16 " wire it the fender behind the lip....I actually thought some years had them factory......anyway I have to hold the torn fender aligned somehow
12-10-2021, 09:13 PM | #17 |
I love it when people try stuff like this. I think you can save it and like you say even if you don't you gain knowledge.
Good Luck |
12-10-2021, 09:13 PM | #18 |
Some fenders that I have worked, have had a factory 'wire'. I wonder if you and Lawson are talking the same thing. No matter, I'd put whatever I needed in the bead, while working on it. And, remove later, if appropriate. Like others have posted, I'd see that fender as a learning experience. And, keep an eye out for a better fender, too. I recently worked some rear fenders on a 38 Plymouth, not quite as bad as what you have shown. I removed a bunch of filler, and putzed around with them over a month or so. When I quit messing with them, I was down to almost needing NO filler. And, if I was more patient, and cared more, I could have probably gone further. I'd call it 'learning', and also a little fun, as long as there is no schedule, and no peers or judge. Obviously, opinion.
12-10-2021, 09:28 PM | #19 |
Thanks.Shu
12-10-2021, 09:29 PM | #20 |
Thanks BOB
