12-05-2021, 06:43 PM | #1 |
B carburetor leak
Recently, I was left along side of the road with a dirty carburetor. After cleaning it with carb cleaner and blowing it out with an air compressor it has my engine running better than ever.
Unfortunately, I have a fuel leak somewhere on the inside of the carburetor, as gas is leaking from the throat of the carb. I replaced all the Zenith B carburetor with new gaskets from Sniders. When I put the car away I always close the in-line valve and run the engine until it quits. Any ideas? |
12-06-2021, 11:28 AM | #2 |
Re: B carburetor leak
Your float valve is bad or your float level is set to high. Check both.
AL in NY |
12-06-2021, 02:52 PM | #3 |
Do what Al says.
12-06-2021, 11:11 PM | #4 |
