11-20-2021, 08:26 PM | #1 |
Manual Choke Wire from Carburetor to Radiator
The choke wire sold by the vendors is brittle and if you have to “un-bend” the end on the carburetor the wire breaks easily. Am I installing wrong or is there a solution?
11-21-2021, 08:50 AM | #2 |
Re: Manual Choke Wire from Carburetor to Radiator
Brass wire may not be the best wire to use for a choke pull. I'm not sure if I know a reason to change the pull loop on that wire. Wire in general, can fatigue with any bending, To unbend tight loops just speeds up the process. I would use annealed aircraft grade stainless steel safety wire and form it myself.
11-21-2021, 11:17 AM | #3 |
If you can locate a factory photo of the bend on the carburetor end, it was a shaped like a straight "Z" so one would pull out on the wire to insert into the choke arm OR only slightly bend the choke arm end so it stays put - it is brittle and you only get one try !
11-23-2021, 09:15 AM | #4 |
I make my own out of 1/8 steel welding or brazing rod. It's fairly cheep and available.
11-23-2021, 09:31 AM | #5 |
Enjoy yer day. Tom Hate can't fix what it started. |
