09-09-2021, 04:12 PM | #1 |
1935-36 Dash Light Switch
I took my '36 dash light switch apart because it did not work. I have just been bypassing it so I thought I would see what is inside and was it fixable. Well, no, its not.
The little L piece near the center is/was attached to the slide mechanism to its left. It fell off and I don't see any reasonable way to reattach it. And from what I have heard from others, correctly one would Pull the switch in order to turn it on. Why Henry thought that was a good idea we will never know. With all of that said, before I do any research, and I have contacted Dennis Carpenter's business, is there any market for for them if I find someone who can reproduce them. Then, do we want them to be exact duplicates, "Pull to turn on" or change it to Pull to turn off. If they cost $50 each, and I am guessing in the dark, is there a market for them? The set up cost is going to be distributed through all the switches made and I don't guess I will sell more than 100 of them. And, yes, I know we don't drive our old Fords at night anyway, I just like everything to work.
Steve in Denver |
09-09-2021, 04:27 PM | #2 |
Re: 1935-36 Dash Light Switch
Interesting. |
09-09-2021, 05:04 PM | #3 |
Pull to turn on seems normal to me, just think of headlight switches.
09-09-2021, 05:13 PM | #4 |
If you're thinking of reproducing Henry's switch then REPRODUCE IT, don't change anything. If you do, it's not a reproduction. Jeeeeeezzzz
09-09-2021, 05:24 PM | #5 |
Good points, thanks
Steve in Denver |
09-09-2021, 07:24 PM | #6 |
09-09-2021, 07:35 PM | #7 |
Thanks, will see if others think there is a demand.
Steve in Denver |
09-09-2021, 11:04 PM | #8 |
The parts book has different numbers for 35-36-37, later parts books list the 37 switch as replacement, I thought from reading the 35-36 book that one year on was pushing switch, other pulling switch
The 1936 dated parts book lists 3 different switches, standard, deluxe and truck ---though many of the differences may be the knob |
09-10-2021, 07:21 AM | #9 |
35 has opposite operation from the 36-7. The little L shaped rocker sits inside the switch on a cradle it can fall out when disassembling. The insulating material with the two electrical terminals on the rear of the switch warps over time. Placing a very small piece of insulating plastic between the two terminals to keep them straight often repairs the switch.
09-10-2021, 09:05 AM | #10 |
It does look like the "L" connector sits against the end plate.
Steve in Denver |
09-10-2021, 09:16 PM | #11 |
I have two correct and working dash light switches for the 35-37 commercials, and the 34 passenger cars. Anybody need one? Lawson Cox 770 784 0507 [email protected]
09-11-2021, 11:29 AM | #12 |
I believe the '35s and the 36's are different. One is pull to turn on and the other is pull to turn off. I think the 35's are pull to turn on. Jim in San Jose
09-15-2021, 01:26 PM | #13 |
Hi Lawson, I sent you an email about a 34 dash light switch. Ken
09-15-2021, 02:00 PM | #14 |
Yeah, I got it. Thanks.
