08-26-2021, 12:50 PM | #1 |
Steering column support Q.
I installed a31 column support on my 30 roadster. Easy install and worked GREAT !
Will same mod work for same purpose on a 29 coupe ? Will install be same/easy ? |
08-26-2021, 01:35 PM | #2 |
Re: Steering column support Q.
Wasn't there a recent article in either the Model A News or The Restorer about adapting the 31 steering wheel support to 28-9 cars? It can be done.
08-26-2021, 01:40 PM | #3 |
The later column support can be mounted on 28-29 cars, however, you need to make an adapter. The attached article describes how it is done.
Tom Endy |
08-26-2021, 06:04 PM | #4 | |
Thanks much ! That article is spot on perfectly answers my inquiry in detail !! And pictures are always welcome. You are a good teacher, indeed ! |
