08-20-2021, 09:37 AM | #1 |
checking model A for cracked head
Having issue with keeping coolant in radiater, are there ways to check for a cracked head or block?
08-20-2021, 10:23 AM | #2 |
Re: checking model A for cracked head
They usually will lose coolant in one of two ways. The first is they will crack near an exhaust port. You can tell by either looking at the tail pipe for carbon deposits on the floor or steam when you shift going down the road. Obviously you need someone behind you when driving. Another way to check is to pull the manifold and look in the ports. Another way is that you will have a blown head gasket, usually between 1/2 or 3/4. That requires a comp. check. Mine was leaking out an ex. port and I found out from the guy behind me-and the fact the rad was stone cold after driving some distance. A can of Bars leak pellets and still no loss of coolant. There are smarter people who will chime in here but those are some things to check.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
08-20-2021, 10:35 AM | #3 |
Checking for coolant in the oil and oil in the coolant is a fairly easy way to rule some things out.
08-20-2021, 10:42 AM | #4 |
Just curious, wouldn't a leaky head gasket cause the symptom of losing coolant? I imagine it does not have to be a cracked head or block.
08-20-2021, 10:45 AM | #5 |
Pull the spark plugs and look at the top of the pistons, if one or more pistons look cleaner than the others, you probably have either a crack or a leaking head gasket.
08-20-2021, 10:51 AM | #6 |
08-20-2021, 02:55 PM | #7 | |
same amount of coolant each time, like a quart or so, it will kick it out through the overflow tube until it seeks the level it likes. That is the way mine does and others have said the same. Hope that is all that is happening.
IN GOD WE TRUST - SEMPER FIDELIS John |
08-20-2021, 07:49 PM | #8 | |
altho my truck with a used radiator after idiling for awhile would eventually puke its coolant out. turns out after removing the radiator, soaking in liquid plumber, then back flushing with a pool pump blasted about 1/4 can of excess water pump grease out. after that no more overheating or puking. can idle all day. all too often people pump alot of grease into the water pump and thus gets clumped together clogging the radiator tubes.
1929 Model AA - Need long splash aprons! |
08-20-2021, 09:32 PM | #9 |
You can use a "Combustion Leak Test Kit" which "sniffs" the coolant to check for combustion gasses. These kits are readily available at most parts stores and are not expensive and they work.
If you have a cracked head or block or have a bad head gasket that is leaking coolant into the combustion chamber, this test will usually detect it. I have one in my shop that I use when a crack or bad head gasket is suspected. Chris W. |
08-20-2021, 09:34 PM | #10 |
One way without much in tools is to take off the belt and top hose fill cooling system up to within 1/4 inch of top, crank engine with ignition off and look for bubbles ---if you get bubbles --it may just raise the coolant level at first, there is a combustion chamber to coolant leak most likely you can also start the engine and see if bubbles come in the first 30 seconds or so (after a min or 2 heat may start micro boiling bubbles)
08-25-2021, 08:38 PM | #11 |
Did not replace any parts and just let a fresh antifreeze mix seek it's own level by letting it runout the overflow tube while I drove the car and watched the temp gauge go no higher that 185 degrees. When I parked the car I carefully removed the cap and the coolant level was 1 1/2 inches below the overflow tube and above the radiator tubes. Today I drove the car for about an hour and checked the coolant level. It did not change. I think I just have to remember what one of you mentioned, that these cars do not run full to the top like pressurized systems do and just drive the car and not keep refilling them at too high a coolant level. Appreciate all you advise and that is what is so nice about this sight.
08-26-2021, 10:42 AM | #12 |
Good news ! Go for a drive and enjoy !
08-27-2021, 10:43 AM | #13 | |
