#1 |
Have a 29 special coupe, hard turn causes rubbing on front tire, all stock, 21” tires. Any thoughts?
#2 |
Tire is probably hitting the brake rods. It could be that the tires are oversize. Firestones are a bit oversized. you could fix it by putting a washer under the stops on the axle.
#3 |
Dont do any hard turns!
www.whidbeymodelaclub.com |
#4 |
Are the stop nuts on the front or rear of the axle?
#5 |
My Coker 21" radials are substantially larger than the multiple brands of bias rags I took off. They rub just a little in a tight turn.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. |
#6 |
Also, make sure they are the correct length and are touching the spindle. |
