04-09-2021, 06:35 AM | #1 |
40 ford truck window regulators
Good morning, How do I "loosen" up my window regulators. They start to roll up but seem to bind.I don't want to force them?I tied to pull up the window at the same time but they won't go.
04-09-2021, 08:23 AM | #2 |
Re: 40 ford truck window regulators
It may not be the regulators. The window could be binding up in the door due to the original channel being worn or missing. Remove the steel inspection panel on the doors and unscrew the regulator which will allow the window and regulator to drop down where you can see the regulator. The regulator will slide off the glass track and you can remove it for inspection. If you need to remove the glass to replace the the channel the glass comes out through to opening at the top of the door. While you are at it you might want to remove the door latch mechanism and clean and lube it also.
04-09-2021, 10:19 AM | #3 |
Thanks TJ. B oth door glass are broken so ill be replacing all the windo channel while I paint.
04-09-2021, 04:43 PM | #4 |
If your regulators are too worn to fix let me know as i have a a pair of decent regulators that I would sell.
08-22-2021, 11:55 AM | #5 |
Thank you |
