03-10-2021, 11:52 AM | #1 |
1940 dashboard
30482E00-12EC-4BD3-A0BE-C27E758656D5.jpg This is my attempt to show a picture of the dash board on our coupe.
03-10-2021, 11:56 AM | #2 |
Re: 1940 dashboard
If you decide to honor Bob Gregorie you can use this as an example.
Here's another good thread about the 40 Ford dash. https://www.fordbarn.com/forum/showthread.php?t=156788 Last edited by 19Fordy; 03-10-2021 at 12:04 PM. |
03-10-2021, 08:42 PM | #3 |
Re: 1940 dashboard
I tend to agree in that Gregorie got it right the first time.
03-10-2021, 11:28 PM | #4 |
Re: 1940 dashboard
What a great picture of a 1940 Ford Deluxe Dash and Interior. |
03-11-2021, 07:23 AM | #5 |
Re: 1940 dashboard
The custom fan in me likes it. Was that wrapped or hydro-dipped
03-11-2021, 07:32 AM | #6 |
Re: 1940 dashboard
03-11-2021, 09:50 AM | #7 |
Re: 1940 dashboard
Thanks, the process is two colors of paint then clear. I used water base ppg. The first color is very light tan. Let it dry then spray a coat of dark walnut brown over the tan. While it is wet, lay a plastic shopping bag directly on the wet paint, then lift it off. Repeat the plastic bag application until you like it. I started with a sample part. With water base paint you can clean off the dark paint before it dries and try again.
03-11-2021, 10:13 AM | #8 |
Re: 1940 dashboard
What are your plans for the window garnish moldings, the same grain or a contrasting color?
Sounds like a good graining technique. Last edited by Zeke3; 03-11-2021 at 10:15 AM. Reason: added comment |
03-11-2021, 10:24 AM | #9 |
Re: 1940 dashboard
Here are some photos of the garnish molding
03-11-2021, 11:52 AM | #10 |
Re: 1940 dashboard
03-12-2021, 11:29 AM | #11 |
Re: 1940 dashboard
Did 40 Fords come with pass. side door armrests as an option?
03-12-2021, 11:44 AM | #12 |
Re: 1940 dashboard
When someone restored my convertible in the '70's they painted the dash woodgrain. It reminds me of an old console radio.
03-12-2021, 12:46 PM | #13 |
Re: 1940 dashboard
Jim, they were optional.
03-12-2021, 02:06 PM | #14 |
Re: 1940 dashboard
Kube: Were they also available for both sides on a standard as mine has both.
03-12-2021, 02:14 PM | #15 | |
Re: 1940 dashboard
While common sense might suggest they were optional, if you're seeking points on a judged concourse, I'd suggest you do not install them.
03-12-2021, 03:01 PM | #16 | |
Re: 1940 dashboard
"whatever works!" |
03-12-2021, 03:02 PM | #17 | |
Re: 1940 dashboard
