02-21-2021, 09:30 PM | #1 |
Cast iron 2 groove wide belt crank pulley
I have a cast iron 2 groove wide belt crank pulley used on 48-52 ford flathead trucks. These pulleys are pressed steel but never saw a cast iron one. What were they used on ??? If I remember correctly I bought it from a Canadian collector.
02-22-2021, 01:55 AM | #2 |
Re: Cast iron 2 groove wide belt crank pulley
I just pulled a cast iron pulley off the engine in a ‘46 Mercury.
Double pulley, wide belt. |
02-22-2021, 09:43 AM | #3 |
The 59 series had a different pulley due to the fan location. Canada always did things a little different than Ford US. They had their own foundry and may have found it less expensive to cast rather then deal with dies and presses for such items.
02-22-2021, 11:01 AM | #4 |
I have never seen a cast pulley wide belt pulley for the 8BA.
02-22-2021, 11:39 AM | #5 |
That makes a lot of sense. I installed it on my 8BA engine, no problems. Thanks for your thoughts
02-22-2021, 11:49 AM | #6 |
Charlie ny |
02-23-2021, 09:40 AM | #7 |
02-23-2021, 02:03 PM | #8 |
I think C8BA-6312-B is cast into the back side on those.
02-23-2021, 05:30 PM | #9 |
Cast pulleys like yours were common in Australia also.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
02-28-2021, 07:17 AM | #10 |
German V8 flathead ( Ford Keulen ) has a cast crank pulley for three belts.
