Old 02-20-2021, 12:20 PM   #1
Cliff Ramsdell
Cliff Ramsdell's Avatar
Default 1939 to 1948 ford flathead 3 speed transmission gear set, bearings, gaskets and relat
City: Windsor Locks
State: CT
Price: Sold
Sold sold sold
Morning all,
Working in the shop on my OT project and have stuff here I won’t be using.
This is a complete 39-50 gear set with bearings, shafts, gaskets, snap rings, oil baffles. It’s been a spare set on the shelf for my Model A but I also have a good spare transmission assembly (36) so I don’t need all this too.
The cluster shaft is 29/24/18/14 and the input shaft is 15 teeth.
No broken teeth but some gears show pitting from moisture over the years. The syncro hub was disassembled, cleaned and reassembled. The bearings and really nice, original ford bearings not the new off shore parts. All parts were cleaned and glass beaded and packed up, I would wash everything before assembly. Bearings were ultrasonic cleaned, inspected and bagged in oil.
Both main shaft and reverse shaft are nice along with all the misc parts. New gasket set and the cluster gear rear thrust washer.
$old shipped USPS flat rate in the lower 48 states. PayPal preferred, sent friends and family or you cover the PayPal fees.
Thanks,
Cliff Ramsdell
Cliff Ramsdell is offline   Reply With Quote
