02-15-2021, 05:43 PM | #1 |
Correct toe board 1936 pickup
Can someone help me determine which is the correct toe board for my 1936 1/2 ton pickup? I have both styles and I am finding conflicting information online.
Thanks |
02-15-2021, 06:18 PM | #2 |
Re: Correct toe board 1936 pickup
B without question. It's what I have in my 35. I have seen A but not sure what it's for.
02-15-2021, 06:28 PM | #3 |
[QUOTE=Lawson Cox;1985940]B without question. It's what I have in my 35. I have seen A but not sure what it's for.[/QUOTE
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 02-15-2021 at 07:00 PM. |
02-15-2021, 06:58 PM | #4 |
"A" is large truck!!!
02-15-2021, 06:59 PM | #5 |
02-15-2021, 07:01 PM | #6 |
That’s what I was thinking. I believe A is for big trucks but I keep seeing it advertised as 35 and 36 and B for later years. I just wanted to confirm that B is correct. Now I just need to find the pedal plate for toeboard B. Does anybody have one they’d sell? |
02-15-2021, 07:15 PM | #7 |
Question: On B, where is the hole for the starter switch?
Shouldnt that be between the pedal holes and below the steer shaft hole? |
02-15-2021, 07:21 PM | #8 |
There isn’t one in that generic picture I found online. The attached picture is my toeboard and it does have the hole for the starter switch.
02-15-2021, 07:43 PM | #9 |
02-15-2021, 07:48 PM | #10 |
"B" is definitely later than 35 or 36. "B" has a hole for a headlight dimmer but no hole for 35-36 starter button. Also the foot rest hole is missing. See images of 35-36 toe board.
02-15-2021, 08:02 PM | #11 | |
02-15-2021, 08:03 PM | #12 |
So is my toe board not correct for my ‘36 pickup?
Don, in the drawing of the toe board, why would there be a void or passage hole between the toe board and the trans cover? |
02-16-2021, 12:39 AM | #13 |
Early 35 transmissions had a throwout bearing that was greased from a fitting on the transmission inspection cover. the void in the early toe board and transmission cover allowed access to that fitting. Your toe board doesn't have that void and your transmission cover shouldn't have one either.
02-16-2021, 03:19 PM | #14 |
Thanks everyone. I do need the pedal plate for this style of toeboard. If anybody has one for sale, please let me know. Thanks
02-16-2021, 03:27 PM | #15 |
The reproductions are based off of a 38-39 Board (they lack the starter switch hole and have a hole for a dimmer switch) Otherwise they fit, as I am using a NOS 38-39 in my 36 and I added the starter switch hole. . There is no pedal plate used on these to my knowledge.
02-16-2021, 03:28 PM | #16 |
Here's what you are looking for.
02-16-2021, 11:44 PM | #17 |
02-17-2021, 12:14 AM | #18 |
02-17-2021, 09:33 AM | #19 |
B is correct. I have one in case anyone is looking for one. I also have a pedal plate but it has been butchered a bit. I can't post pictures here.
02-17-2021, 11:42 AM | #20 |
If I cannot source an original pedal plate, I will create tooling to make one for my pickup, with the option to make more if anyone is in need of one.
