02-06-2021, 08:19 AM | #1 |
Any chemists out there?...Red steering wheel restoation
How would you return old hard chunks of the red steering wheel soybean compound BACK into it's original liquid paste that was used before the moulding and hardening process took place to form the steering wheel?
Hmmmmmm. Pluck Last edited by Steve Plucker; 02-06-2021 at 08:25 AM. |
02-06-2021, 09:21 AM | #2 |
Re: Any chemists out there?...Red steering wheel restoation
Steve: My sister is a retired chemist. She says someone who specializes in material science might help you. She also said to research articles written back in the day when Ford was developing this soybean process for making car parts. Good luck.
02-06-2021, 12:49 PM | #3 |
https://www.hemmings.com/stories/201...wn-on-the-farm
General interest article about Fords and veggies back in the 30's. |
02-06-2021, 12:58 PM | #4 |
I am not a chemist but have used various plastics in my mechanical engineering work. There are basically two types of plastics: thermosetting and thermoforming. Thermosetting goes into a mold and gets heated to cause a chemical reaction. This is a one-way street and cannot be undone. Thermoforming can be melted over and over again and is the kind of plastic mostly used in injection molding machines. I believe that the red steering wheels are thermosetting, but to test that try melting a little bit. I think the red plastic is formed by polymerization of the soybean oil, where the individual molecules are linked together to form long chains. Other parts of the soybean are probably added to provide filler. That is about all I can provide.
02-06-2021, 04:52 PM | #5 |
Steve: Can't help with your question, BUT welcome back to this site. Jim...
02-06-2021, 08:06 PM | #6 |
Ask your question directly to Mark Maron. He gave a great seminar at the MARC Meet in Branson on steering wheel restoration. |
02-07-2021, 02:10 AM | #7 |
I recall hearing that someone had ground the "plastic" off an antique steering wheel( I don't recall if it was an A). They mixed it with Methyl Ethyl Ketone as a solvent and was able to repair using original material from a donor. I'm not sure if this was a soy based wheel. This anecdote may be entirely not helpful-but it came to mind.
02-07-2021, 05:06 AM | #8 |
Harp,
I like this thinking. would prob require being resprayed as to match colors though. |
02-07-2021, 08:58 AM | #9 |
02-07-2021, 10:49 AM | #10 |
Henry Ford started his work into development of soy beans for automotive use around 1930. He built a lab for that purpose at Greenfield Village in 1931. The 1928 red steering wheels were likely a phenol-formaldehyde type plastic more closely related to Bakelite thermo-setting plastic. The soy fiber plastics that Ford used later for the 1941 soybean car were most likely made with phenol-formaldehyde mixed with soy fiber materials. The soy polyols that can be used for polyurethane and polyester production are more modern developments from the earlier plastics. Henry Ford got a lot of his ideas from George Washington Carver as early as 1934 when they started corresponding with each other. Several soy plastic products came out of that collaboration in later years.
Once Bakelite is formed & heated, there is no going back to its original state. A person may be able to recast one with a Bakelite type process but I don't know of anyone who does this. An old red 1928 model A wheel could be repaired just like a hard rubber wheel and painted to look original with the right color mix or it could be recast with modern resins and tempered the way most steering wheel restorations are done in this day and age. Last edited by rotorwrench; 02-07-2021 at 10:56 AM. |
02-07-2021, 12:28 PM | #11 |
When I was a child, in school, probably around 1950, they taught us that plastics were made from trees. Nowadays they're mostly made from petroleum.
02-07-2021, 06:43 PM | #12 |
Steve, do you have the pieces?
02-07-2021, 08:16 PM | #13 |
