01-31-2021, 08:57 AM | #1 |
Marvel Mystery Oil
I have an engine that last ran about 10 years ago. A while back I had heard good things about Marvel Mystery Oil. Now that I am thinking of using some in this engine I find that they have products for use in the oil and for use in the gas.
Need some advice on which to use on engines that haven't run for some time. Stories are always good. Thanks for your help on this. Dean |
01-31-2021, 10:03 AM | #2 |
Re: Marvel Mystery Oil
Put in about 4oz of MMO per 10 gals of gas.
Also squirt some oil (a lot) in the spark plug holes and let it sit for a few days before you start her up. |
01-31-2021, 10:59 AM | #3 |
I have had good luck with sea foam. I cant compare it to mmo since I haven’t tried mmo.
01-31-2021, 11:49 AM | #4 |
It's my understanding MMO is also a solvent. I've soaked a few rusty bolts that allowed me to remove them without damage useing mmo
01-31-2021, 11:51 AM | #5 |
Used MMO for years. Just follow the directions. If your glass sediment bowl is pink your motor will smoke like a bitch for about 10 minutes. I haven't
been driving our Tudor much at all but when I do I pull the plugs out squirt some MMO in each hole and roll'er over with the hand crank slowly. Reinstall the plugs and light'er off. |
01-31-2021, 11:52 AM | #6 |
01-31-2021, 01:37 PM | #7 | |
01-31-2021, 08:58 PM | #8 | |
01-31-2021, 09:09 PM | #9 |
Good stuff - great for sticking valves !!
02-08-2021, 10:12 PM | #10 |
I have seen MMO now packages specific crankcase oil too, I believe the fellow that does all the 4 cylinder work for H and H has them as a sponsor on his personal car.
Modelacrazy |
02-09-2021, 06:40 AM | #11 |
I use MMO in my gas as much as I can remember too. I just use an ounce or two as I really don't drive that much anymore. One thing that MMO did for my "A" was to stop vapor lock on my carb. Florida is where I live and vapor lock can be a problem. An unusual thing I found about MMO is that
every time before I go driving. I always check the bottom of the carb to feel if it is leaking. Normally there will be a small residual of MMO that has collected. Not gas, but definitely MMO. Am I adding to much maybe?? Bob-A |
02-09-2021, 10:17 AM | #12 |
I've use MMO and seafoam and like them both. I have a'74 Ford 1 ton that was parked for a long time and i needed to use it. I drained the fuel and put in fresh and got it started but it ran poorly. Wouldn't idle at all, anything under 1000RPM and it would stall. Had my son hold it at 2000-2500RPM while i poured MMO down the carb. Poured until it almost stalled, let it catch it's great that poured some more. Did this 3 or 4 times (used 1/3 of the bottle) and the truck ran and idled smooth. Pretty sure to was sticky valves. Made a LOT of smoke. pouring either MMO or SF into the carb while running is good for cleaning the combustion chambers and all mechanical related, IE valves, rings. I fail to see how pouring into the carb while running would affect the jests in the cab since it is in the air flow and is therefore introduced downstream of the jets but pour it in the fuel and it will clean the carb including the jets. I good way to clean the valves and rings I'm told is to pour it in the car while running until it stalls and let it soak for 20 minutes or so. I done;t recall if I've ever tried that to not but sounds logical.
02-09-2021, 10:33 AM | #13 |
Posted this in wrong place
02-09-2021, 07:13 PM | #14 |
Marvel mystery oil had been around for a long time,I recall when I first got interested in antique cars back in the late 1960s my great grandfather had a can of it in the garage.They also had a top Oiler setup that hooked up to the intake manifold, looked like a mason jar with a bracket.
02-10-2021, 04:39 AM | #15 |
MMO is a great lubricant. always put some in the gas tank to clean out anything sticking.
if it smokes for a bit, you know you are cleaning up the ill gotten mosquitos! |
02-11-2021, 11:45 AM | #16 |
Correct me if I'm wrong but I think I remember Studebakers back in the early 50's had some kind of set up mounted on the firewall that fed mmo into the engine.
02-12-2021, 08:37 AM | #17 |
When an engine has not run in a long period of time, the oil feeds to the bearings bleed out, so the engine has inadequate lubrication upon startup.
In Model "A" & "B" engines, it is imperative that oil supply chambers and passages are full. Thus the practice of pouring at least a quart of oil down the distributor shaft hole is a must do before starting a stored engine. Further more, it is also imperative that the troughs in the oil pan tray have oil to lubricate the connecting rod bearings. So at least 3 quarts of oil need to be poured into the crankcase breather tube. Next consider the transmission. When starting an engine just out of storage with the transmission in neutral, the main shaft turns, so the transmission needs to have an adequate level of oil to lubricate the front main shaft bearing. The cluster gear also spins, and it has 2 roller bearings that need oil. Be sure the transmission oil level is adequate before starting the engine.
Bob Bidonde |
02-12-2021, 12:02 PM | #18 | |
In the 40's and 50's my Dad told me that people used to have a set up like that where they would dribble a little water into the carb intake to get better fuel mileage I guess. He said the theory was that your car always ran a little bit better in a rain storm. Whether that worked or not I don't know. |
02-12-2021, 12:18 PM | #19 | ||
OK, back to the main subject.
Ruth "Sometimes you really DO need to read the whole thread" |
