Old 01-22-2021, 07:40 PM   #1
melisahe
melisahe's Avatar
Default ford f1 cowl assy
Does anyone know if the bolt assy that holds the cowl handle assy together is a axel type(shoulder) bolt. A regular bolt dosn't make it work properly. I've tried a few different combinations trying to get it to open and close properly but so far no luck. All help deeply appreciated. Thank You, Mike
melisahe is offline   Reply With Quote
Old 01-23-2021, 01:18 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: ford f1 cowl assy
Are you asking about the bolt that is spring loaded and runs in a slot? Someone posted a pic with dimensions in your other thread. It's a regular bolt with a prevailing torque (self-locking) nut, that can be tightened part-way and not loosen.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 01-23-2021, 04:32 PM   #3
1948F-1Pickup
1948F-1Pickup's Avatar
I posted it.
No idea what Ford's actual part number is for that. Can't find a diagram in the parts books....
I'm guessing they expected you to either-
A) replace the whole assembly or
B) use a hardware store bolt
Looking at that bolt, it looks like it has an awfully long shank for
a bolt with that kind of overall length. Probably a longer 1/4" bolt,
with the threaded end shortened, would do the job.
1948F-1Pickup is offline   Reply With Quote
Old 01-23-2021, 04:52 PM   #4
1948F-1Pickup
I take that back. Looks like maybe 1/4" to no more than a 3/8" shoulder on that
bolt..... I just looked under my dash.
A 1/4" bolt at 1 1/4" long has a .29" shoulder. I have one in my hand.
I don't think that bolt is anything trick.
I'll bet you'd need to have those washers with the shoulders though and pretty
close to the spec in that drawing.
