01-17-2021, 11:11 AM | #1 |
Manifold Heater Mount
I acquired this manifold heater with the car. How do these typically mount to the exhaust manifold? This heater has two through bolts as shown in the picture? Appreciate any insight
"no one knows more than everyone" |
01-17-2021, 11:38 AM | #2 |
Re: Manifold Heater Mount
Autolite heater manifold (waffle top style) is needed. It is secured with two small bolts through the top.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
01-17-2021, 11:40 AM | #3 |
It requires a heater mangold for it to fit over. Then the two bolts pass through the heater and screw into the manifold. The heater manifold I had was taller, more square and fluted than the standard manifold.
01-17-2021, 03:42 PM | #4 |
Thanks Guys, Yes I have seen those waffle style, unfortunately my car does not have one at the moment
01-18-2021, 12:18 PM | #5 |
I believe the heater cover you have is used over the standard Model A exhaust manifold. The cover that goes over the Autolite waffle heater manifold looks like this.................
The heater cover you have goes over the stock exhaust manifold by removing the rear through bolt, then place the cover over the stock manifold, re-insert the bolt and tighten it to secure the cover.
AL in NY Last edited by AL in NY; 01-18-2021 at 12:23 PM. |
01-18-2021, 12:29 PM | #6 |
01-18-2021, 03:56 PM | #7 |
Thanks Guys, I will give this another look, if anyone does have a picture of this type installed that would be great
01-18-2021, 11:15 PM | #8 |
Here's mine...
heater.jpg |
01-19-2021, 12:10 AM | #9 | |
01-19-2021, 06:15 AM | #10 |
Thanks Fred, what is securing the heater to the manifold(other than the hose)
Is your manifold a stock round body?
01-19-2021, 10:23 AM | #11 |
Yes my manifold is stock. The two halves of the heater fit around the manifold and are held together with two bolts.
