01-05-2021, 07:22 PM | #1 |
Prony Brake Ideas
This is my concept of a simple Prony Brake Dyno.
It's probably a little over kill to use a 1 1/2 ton disk for a 150 HP engine but, it would be trouble free, I think to at least 250 HP. The way I drew it, is with a screw, to activate the MC. That way you could leave it will doing initial break in and it would make it easier to hold a torque reading. Again, with this type of brake, the HP, uses the formula, Torque x RPM Divided by 5252.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 01-06-2021 at 01:53 AM. |
01-05-2021, 10:20 PM | #2 |
Re: Prony Brake Ideas
OK, well this answers a lot of questions. But does the master cyl work on a 12" lever? I'm thinking so. Does the flywheel weigh 1 1/2 tons? I bet the engine idles real smooth at 150 rpms. Personally I wanted to just add a load to my engine stand for proper ring break in and not care much about how much horsepower my puny 221 cu in stock mill with new rings and valves was putting out. Your whole setup would work really well for me. I have 2 beater, untitled '47 truck frames I can cut off as far back as needed. Let's get started!
01-05-2021, 10:25 PM | #3 |
GB, i like your oak plank better...less maintenance.
01-06-2021, 12:07 AM | #4 |
Just wondering if an automatic transmission plus torque converter with output shaft locked would provide enough load for run-in purposes.
01-06-2021, 01:37 AM | #5 | |
I'm not sure what your saying about a 1 1/2 tons. I was saying that the disk brake rotor would come from a 1 1/2 ton truck, for it increased capacity over a car rotor. I brighten the drawing, to make it easier to read. I also forgot to add a throttle lever to the panel, for the carb.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 01-06-2021 at 01:58 AM. |
01-06-2021, 11:18 AM | #6 |
01-06-2021, 11:48 AM | #7 |
I am trying to ignore this subject because if I'm not careful, it'll get me into another project that I don't have time for. Given that, I was thinking big truck brake too.
The bad thing is that I already have an electronic high capacity load cell I'm not using. |
01-06-2021, 12:00 PM | #8 |
I remember a long time ago, one of business partners of the company I worked for built a water brake to put a load on the small diesel engine powerpack he was designing for Class 8 Trucks to generate heat to heat the cab as well as generate electricity.
01-06-2021, 05:52 PM | #9 |
I have a neighbor that likes to smolder grass and leaves when the wind is blowing my direction. I have pondered long and hard about getting one of those airboat props and cages. It wound be perfect for breaking in an engine.
01-06-2021, 07:38 PM | #10 |
It seems like that brake rotor would get really hot, like red hot. Maybe you could run a water jacket around it and make coffee.
01-06-2021, 09:25 PM | #11 |
In the late 50's our company got involved in building quarter midget engines and needed a dyno to develop them. There was nothing commercially available so we built one using a V12 Allison coolant pump for a brake. It was a total loss system with just a garden hose for water supply. We never did have an engine on it that got it hot. The engines we were working with made around 25 hp.
01-06-2021, 09:28 PM | #12 |
all these inventive thoughts, but you could just hook it up to a generator and sell the power back to the elec. co. and make AOC happy too!
01-06-2021, 10:24 PM | #13 |
my Dad in the Navy during WW2. check the engine/dyno
01-06-2021, 10:27 PM | #14 |
Easiest idea of them all ! I have an outboard motor from 1926 that really puts a strain on it's two stroke ,2 cyl opposed air cooled motor. I have run it at the antique steam, gas, threshing meet at Lynden many times. I have two Vietnam era belly tanks about 21' long... A catamaran with a v8 prop engine? And what's a 'cage'? BTW, not my first rodeo with a prop. At 18 years of age I built this ice craft with a 1 1/2 hp briggs. The police kicked me off the ice with a bullhorn, because of endangerment to all the skaters....,and it was the town's water supply. No gas engines. Sheesh, spoil all the fun.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 01-06-2021 at 10:36 PM. |
01-06-2021, 11:30 PM | #15 |
Not sure of flywheel weight, but there is one at Rollag, MN that is used constantly to measure both PTO and belt HP of gas, diesel, and steam tractors during the three days of the steam threshers reunion. The wheel is run in a band that can be continually tightened for resistance. The lower part is in a water bath. Watched a Case 110 steamer get belted up. HP was 125, torque calculated to over 4,000 ft lbs.
At night a steamer is belted up and really made to shake the ground with its draft. Then, grocery bags stuffed with sawdust and ground corncobs are fed into the firebox. Sparks are belched 30-40 feet into the air, it is quite the show. I wish I could have seen Kory Anderson's 150 Case belted to the brake in 2019, the year he debuted it. Only 9 of these steamers were built. He got the blueprints from CaseIH, and proceeded to build one from scratch. The only surviving piece to be found was the remains of an original boiler.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-07-2021 at 11:51 AM. |
01-07-2021, 02:31 AM | #16 | |
I checked the heat transfer rate and the heat transfer coefficient of water is about350 times that of air.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
01-07-2021, 06:38 AM | #17 | |
here is a video of that tractor. I have never seen a plow that wide. https://truebluesam.blogspot.com/202...-fires-up.html John
Welcome each day |
01-07-2021, 07:23 AM | #18 |
Thanks for the video post. I have seen it in person, just not on the brake. The story is impressive. His goal from childhood was to have one of these extinct tractors. I dont think he is much past 40.
I dig coal, which provides motivation for EVs. |
01-07-2021, 08:29 AM | #19 |
John, that was amazing!!! I tried to listen when he said how many "bottoms" that plow had and couldn't quite make it out. Think my maximum plowing experience with our John Deere's was maybe a two bottom by comparison!!
That is an also an amazing project, considering they had to make everything from scratch, based on the Case blueprint. Thank you for posting!!! |
01-07-2021, 08:40 AM | #20 |
36 bottom plow. It is amazing to watch it steam along in person.
This is not an advertisement. Just a link to the industry he created to build the Case. Now it makes him a living. Kind of like a modern day Henry Ford. https://anderson-industries.com/
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-07-2021 at 08:45 AM. |
