10-03-2020, 12:08 PM | #1 |
Problem Removing Steering Wheel
I need to remove the steering wheel on my '34 to replace the bushing in the steering column with an upgrade bearing.
Before I can remove the wheel I need to remove the lights and horn button assembly and in order to remove that I need to remove the tab at the bottom of the control rod. See photo. My problem is that I have not been able to remove the tab. I have tried prying on it but without much success and I'm afraid I will damage the cup that surrounds the tab. I will appreciate any suggestions and comments. Thank you. |
10-03-2020, 12:19 PM | #2 |
Re: Problem Removing Steering Wheel
Are you referring to the fork on the bottom of the rod after you have removed the light switch?
10-03-2020, 01:10 PM | #3 |
Assuming you are referring to the C-shaped clip that retains the two-prong switch actuator, you might consider sacrificing a cheap screwdriver wide enough to capture the ends of the C and grind or file the center of the screwdriver blade to create a very limited use tool for this purpose.
10-03-2020, 01:16 PM | #4 |
Near the bottom of the horn rod there is a recess in the recess is a C-clip. The C-clip holds the light switch spider and spring in place. The C-clip has to be removed usually by compressing the spring a little. All the parts have modern replacements, except the rod itself. At the very end of the rod is a plastic insulating insert be careful not to damage the plastic. Once the C-clip is removed the spider and spring will slide off the horn rod.
10-03-2020, 03:14 PM | #5 |
Be VERY careful to NOT BEND the light rod AT ALL as if has a bend turning the steering wheel will turn the lights on and of !!! kerk
10-03-2020, 03:21 PM | #6 | |
Do I need someone at the steering wheel to keep the light control tight against the steering wheel while I push the light switch spider back to expose the C-clip? Will I then be able to remove the C-clip with needle nose pliers? |
10-03-2020, 04:09 PM | #7 |
I use a heavy yardstick under the steering wheel and over the horn button to keep the rod pushed down. Maybe this will help you.
Ken
https://www.nirgv8.org |
10-03-2020, 05:45 PM | #8 |
Might want to be sure the battery is disconnected during all of this!
10-04-2020, 08:23 AM | #9 |
Also be careful as that seem to fly around either during removal or installation like the small carb clips ("jesus" clips).
Paul in CT |
10-04-2020, 10:25 AM | #10 |
This picture may help.
10-04-2020, 11:25 AM | #11 |
I Just push up on the pronged tip in the pic above post by BobC and the horse shoe clips comes out pretty easy .
10-04-2020, 11:48 AM | #12 |
Yes, "the horse shoe clips comes out pretty easy", getting it back in is the fun part ...
10-04-2020, 12:28 PM | #13 |
Kens 36's suggestion to use a yard stick across the horn button and underneath the perimeter of the steering wheel is a big help for either removal or installation of the C clip, as is Bob C's helpful illustration of the component parts including the spring that has to be compressed to remove the pressure holding the clip in place.
10-11-2020, 02:43 PM | #14 |
Thanks to everyone who shared their experience and knowledge. With your guidance and another pair of hands from my son I finally got the light control shaft removed.
Now my problem is removing the steering wheel itself. I have a decent selection of pullers but I'm concerned that standard pullers will damage the back side of my original '34 steering wheel. So, here i am again asking for help for ways to pull the steering wheel off of the steering shaft. |
10-11-2020, 03:12 PM | #15 |
You can drill and tap the steering wheel hub, I suggest 5/16"-24, and then use one of these pullers. They're available at any auto parts store and reasonable.
10-11-2020, 07:49 PM | #16 |
I like the idea to use a bearing separator under the steering wheel if you don't have the K.R. Wilson puller.
01-08-2021, 06:18 AM | #17 |
To remove the steering wheel from your 1934 Ford with ease, you need one of these dedicated Ford Steering Wheel Pullers. |
01-08-2021, 06:58 AM | #18 |
What glennpm said works.I have a '33 and did that - now no more issues to remove the steering wheel.
01-23-2021, 03:31 PM | #19 | |
that is the solution I needed, Gregger
When you turn on your car, does it return the favour? |
01-23-2021, 03:43 PM | #20 |
Great its pretty easy, doesn't show and the tool is cheap too. Glad it worked out for you Greg!
Glenn |
