07-28-2020, 10:12 AM | #1 |
Horn bracket
If I unbolt a head bolt to attach a horn will it be a problem with the head gasket?
07-28-2020, 03:39 PM | #2 |
Re: Horn bracket
No as long as the bolt is long enough to go thru the bracket and have sufficient threads to tighten.
07-29-2020, 08:30 AM | #3 |
Re: Horn bracket
You should drain all the water from the radiator first. Then, when retightening, loosen all the head bolts and re-torque them following the correct sequence.
07-29-2020, 10:11 AM | #4 |
Re: Horn bracket
