06-06-2020, 10:07 PM | #1 |
Missing hand throtle part
On my 36 coupe which has a flathead with a Ford EAB carb there was a piece that connects the hand throttle rod to the carb...well it fell off on a ride the other day. The missing part appeared to be bronze or brass and was shaped like a little helmet and inside was a spring. This little helmet fit over a( T )shaped piece that the hand throttle rod is hooked to.
Anyone know what I am talking about ? If so, where can I get one and what is it called ? |
06-06-2020, 10:33 PM | #2 |
Re: Missing hand throtle part
Zig you will need to buy the whole length of rod that is joined under the dash its about 3 ft and crimped to the dash knobs ,any early Ford suplier such as Carpenter ,Macs ,Speedway ,
06-07-2020, 06:20 AM | #3 |
Vintage Speed has nearly all the parts for the 94. Check out their web site. What ya doing with a EAB on a 36? How about a photo of your engine.
06-07-2020, 06:25 AM | #4 |
This what you need?
06-07-2020, 07:06 AM | #5 |
If what deuce posted is the part (my thoughts as well), you should contact CharlieNY as he probably has a box of them for his carb repairs.
06-07-2020, 08:23 AM | #6 |
06-07-2020, 04:48 PM | #7 |
Help me out deuce lover, does that end piece on the right also have holes in it to put a holder through, as well, to keep it from falling off the shaft? At least that is what's on my throttle at the carb on my 36. A cotter pin will suffice here.
06-07-2020, 10:20 PM | #8 |
Thank you Deuce...just what I needed....bought one on Ebay….
06-07-2020, 10:22 PM | #9 | |
Sal |
06-08-2020, 06:40 AM | #10 |
The above parts are for the 94 if you have a Stromberg they look like the pieces below which use a tapered pin to fit into a hole in the throttle shaft for attachment.
06-08-2020, 08:00 AM | #11 |
Yes, that's my set-up on my Stromberg 48. Thanks, Terry. Didn't mean to confuse people. terry
