12-22-2019, 06:02 AM | #1 |
electric seats
I would like to convert my 40 ford coupe bench seat to electric. This is one that hinges at the top of the back for rear access. Has anyone done this and can steer me in the right direction? If the seat ends up a little higher that would be fine. Thanks
12-22-2019, 08:48 AM | #2 | |
Re: electric seats
Charlie Stephens |
12-22-2019, 09:09 AM | #3 | |
Re: electric seats
Your first consideration is, do you have a 12 volt system? Then it becomes a search for anything that is available that will fit the confines of your interior dimensions with minimumal modifications. Suspect anything that is available would be too wide to fit your interior unless someone is making something in the aftermarket to fit.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 12-22-2019 at 09:15 AM. |
12-22-2019, 10:14 AM | #4 | |
Re: electric seats
You will need the motor, relay and switch. These do show up on e-bay from time to time. Since yours didn't have a power seat you will also need to make a motor bracket to weld to the front of the seat frame. The front of the motor hangs in the bracket and the screw shaft is mounted to the floor. (I had to lighten the picture to show it) All you need to do is provide power to the relay and you are good to go. I threw in the last picture just to show you what it takes to covert from a 2 way to a 4 way, all factory. Last edited by Merc Cruzer; 12-22-2019 at 11:58 AM. |
12-22-2019, 01:45 PM | #5 |
Re: electric seats
Adapt the track to the floor using the original seat mount holes; we trimmed off and welded new pieces on the GM track; keeping the floor unchanged. The cables should have enough flex to make up for the narrower width. Then fit the bare seat frame on the tracks and fabricate mounts welded to the seat frame to connect the two. The one I worked on was a Tudor sedan folding back seat; not sure how your hinged back seat base is constructed; if it is a tray like earlier coupe seats it may be more work. The cable are kinda like speedo cables and can be modified too if needed. Last edited by rich b; 12-22-2019 at 01:46 PM. Reason: extra |
