11-09-2019, 09:58 AM | #1 |
Two barrel card spacer with pcv
Does any company make a two barrel carb spacer with a PCV port ??
11-09-2019, 10:23 AM | #2 |
Re: Two barrel card spacer with pcv
If not, should be easy to make?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
11-09-2019, 10:58 AM | #3 |
What year and carb style? You are upgrading?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
11-09-2019, 04:00 PM | #4 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
if you're using a 2100 Ford 2 bbl, just about any mid to late '60s 302 or 351W has what you want
11-09-2019, 05:27 PM | #5 |
If you go past 1972 generally you will find it will have a egr valve attached.
11-09-2019, 09:29 PM | #6 |
11-10-2019, 02:23 PM | #7 |
Check speedway automotive for the Stromberg style 2 barrels (3 bolt mounting bases) - they should have different heights. Also... and I hate to say it, ebay.
https://www.ebay.com/itm/For-Strombe...AAAOxydB1Si8re
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
11-11-2019, 11:32 AM | #8 |
Go to Ebay and in the search bar, type in C4AE-9A589-D and take a look at that spacer.Might be what you are looking for.
11-11-2019, 02:14 PM | #9 |
I need a 3 bolt mounting base not the 4 bolt...please let me know is someone runs across a supplier...thanks
11-11-2019, 05:05 PM | #10 |
11-11-2019, 06:14 PM | #11 | |
Too bad the vendor wasn't listed. Should also consider a phenolic spacer between the carb spacer and carb body.
11-11-2019, 06:15 PM | #12 |
40cpe... the spacer on the left, does that have a port for a pcv hose ?
How large an opening is needed for a pcv hose. Looks like a small diameter...thanks for finding this for me. Who is the vendor ? |
11-11-2019, 08:29 PM | #13 |
The seller looks to be a HAMB member (2900 plus posts). It looks like you will have to get a screw in nipple to attach a hose. Contact the seller for info if you are a HAMB member
11-11-2019, 08:57 PM | #14 |
Click on the HAMB link. You will have to ask those questions to the seller.
11-12-2019, 07:33 AM | #15 |
Don't the gas heaters (southwinds) have what you are looking for? I do not know if the port is the correct size.
The picture above looks like one. |
