10-08-2019, 12:04 PM | #1 |
Running without a torque tube center bearing ?
Looking for practical advice from those who have Not run a torque tube center bearing.
Question is - if I do not run a center bearing in my 41 Ford car torque tube - is there any practical negative issues to expect? I know earlier year Fords did not use the center bearing so I’m thinking of removing it entirely. Reason is that I have had a Skip Haney bearing fail and cannot locate a good used or nos center bearing... |
10-08-2019, 12:07 PM | #2 |
Re: Running without a torque tube center bearing ?
Would it have been engineered and added in the first place if there was no reason for it? Ask yourself and answer that idea. Were there other factors causing bearing failure?
10-08-2019, 12:23 PM | #3 |
The earlier driveshafts (without the bearing) were actually built-up utilizing a long piece of tubing of a rather substantial diameter, not un-like the basic idea behind current-day drive shafts. When you rotate a piece of tubing at the speeds that driveshafts normally turn, the very physical make-up of tubing resists any kind of bowing or "whipping" in the center of the span. On the other hand, Henry decided that it would be cool (probably 'cuz they're easier to manufacture) to start making the driveshafts out of one solid piece of machined steel shaft material. As long as those drive shafts (like the one in your '41) are, they can tend to whip in the middle at higher speeds if not supported in that bearing. Clear as mud, right? DD
10-08-2019, 12:57 PM | #4 |
Give Fred at Southside Obsolete in MN a try.He might have a NOS one.
10-08-2019, 01:19 PM | #5 |
For sure, someone in the Ford old car world has one of those bearings sitting on a shelf.
Yes, they are hard to find and very pricey if you do find one for sale. I am convinced that a modern day encased in rubber bearing could be adapted to fit inside the 41 torque tube. The idea would be to drill and tap the torque tube for several 3/8 x 24 set screws which would hold the bearing in place. A second retainer could also be made and fitted inside the torque tube so that it pressed up against the center bearing. That retainer would also be held in place with set screws. It would be worthwhile to experiment on an old torque tube.The OEM center bearing uses roller bearings thru which the driveshaft slides. It's not a tight fit. https://www.fordbarn.com/forum/showthread.php?t=186780 and peruse this: https://www.google.com/search?q=rubb...hrome&ie=UTF-8 and something like this that could be adapted if the ID was correct. My experience has been that the OEM center bearing itself doesn't fall apart or wear out. Instead,the outer rubber case deteriorates rendering the bearing useless and it literally falls out of place. In the photos below,the big black blob is the dissolved rubber.The metal bearing buried in the blob was still good. I am thinking that there must be a way of making a new rubber casing of the required OD so that the old bearing could be reused. With today's polymer technology perhaps a rubber compound could be poured around the OEM metal bearing ,making it reusable. For instance, the polymer used for making skateboard wheels. It would be fun to try. Last photo is of the tool I made to install the new OEM bearing. Without the center bearing,I think the whipping action of the drive shaft would put extra wear on the needle bearing at the front of the torque tube. Not good. Last edited by 19Fordy; 10-09-2019 at 10:02 AM. |
10-08-2019, 01:33 PM | #6 |
10-08-2019, 01:43 PM | #7 |
Well I ended up getting a original bearing so will install - V8COOPMAN made a good point on the differences between tube and solid driveshafts
Thanks fellas John |
10-08-2019, 03:18 PM | #8 |
MEMBER EMERITUS
Skip Haney sells a replacement - at least he used to.
10-08-2019, 04:47 PM | #9 |
See post #1
10-08-2019, 07:24 PM | #10 |
THE important question here would be.....Does Skip warrant replacements (that have gone south) that he used to sell? DD |
10-08-2019, 07:37 PM | #11 |
He did send a replacement bearing, though that does no where cover the shop cost to remove rear axle asm fix bearing and reinstall
Given the first bearing failed after 680 miles, I was not about to try again so found an original Ford bearing based on feedback here |
10-08-2019, 07:51 PM | #12 |
Make positive sure the shaft is straight.
10-08-2019, 10:51 PM | #13 | |
10-09-2019, 06:14 AM | #14 |
That's a good point Jeff, and also who's to say the "mechanic" who installed the first Skip Haney bearing in the '41 torque tube didn't do something correct, and screwed that bearing up, possibly causing it to fail early.
10-09-2019, 07:40 AM | #15 | |
10-09-2019, 07:48 AM | #16 |
Put a Mitchell in it and the bearing problem is gone, plus you have overdrive.
10-09-2019, 08:24 AM | #17 |
Just a thought here for any of us with a late '37 to '40 or '41 pickup.......if the torque
tube center whip bearing fails it is quite possible to replace the solid drive shaft' with a '35 - early '37 tubular drive shaft. I bore the fine female spline out of pinion end of the shaft and press in the six spline adapter from the solid shaft. I button weld the adapter in place and that is the end of that issue. I always keep one of these tubular drive shafts handy. Charlie ny |
10-09-2019, 09:06 AM | #18 | |
The tubular shafts for the early Fords up to 1938 or so were either short enough or well shaped & large enough plus being fabricated from steel, that they didn't need a damper to calm the shimmy that naturally happens with long solid shafts or smaller diameter shafts. Dampers also help protect the U-joints on the shafts that use them. |
10-09-2019, 10:03 AM | #19 |
Another torque tube design question:
Question: Would it be possible to redesign the outer hollow torque tube by accurately cutting it in 2 pieces near the location of the center bearing and welding a steel flange on each half such that the torque tube could be bolted together (on center) like 2 pipe flanges? There would be an interlocking lip on each flange for concentricity.. That way you could have easy access to the center bearing, if needed. I realize the OEM torque tube acts like a torques arm for the entire rear end with lots of forces being generated. |
10-09-2019, 11:13 AM | #20 | |
