05-07-2010, 07:15 PM | #1 |
Trans options?
We're looking to swap out the trans in the '60. The 292 Yblock was gone through recently and would like something that gear wise will get down the highway a bit better.
Anybody have any suggestions or advice for an upgrade without having to break the bank? Thanks, Jerry |
05-07-2010, 07:31 PM | #2 |
Re: Trans options?
What do you have in it now? My '56 had a 3spd in it, I swapped it for a toploader 4spd out of a '66 Comet that I had so I don't know how much one would cost. I replaced the original POS ford shifter with a Hurst. Haven't put enough miles on it to know what kind of mileage it'll get but it'll pull out pretty good behind the Yblock.
ron |
05-07-2010, 07:55 PM | #3 |
Re: Trans options?
Thanks for the info. I believe it's a two speed cruisomatic.
05-07-2010, 08:39 PM | #4 | |
Re: Trans options?
throw out bearing and your good to go get an older unit or you will have to change the tailshaft for the speedo gear newer units are electronic |
05-07-2010, 09:25 PM | #5 |
Re: Trans options?
Well I do know there are some C-4 adapters along with an adapter for a T-5 swap . Trans Dapt and John Mummert has adapters for both . I also have seen one for an early AOD , the one without the computer shift . You have many good upgrades to replace what you have now !
Jim |
05-07-2010, 09:50 PM | #6 | |
Re: Trans options?
If not interested in an overdrive trans, the top loader four speed or a C-4 would be good choices. Last but not least would be a stock three speed with overdrive. |
05-08-2010, 08:51 AM | #7 |
Re: Trans options?
If you have an auto. go with the AOD, adaptors are out there, if you have a manual the T-5 is the way to go. T-5 is what I have in my pickup. BSC in Costa Mesa advertises in Y-Block Mag for AOD conversions 949 722 1122 no website.
05-08-2010, 11:08 AM | #8 |
Re: Trans options?
I used a T-5 from a mustang V-6 but put the S-10 tailshaft to move the floor shift forward away from the seat. Been driving it over a year and love it ! (1954 Sunliner)
ripper |
05-08-2010, 11:49 AM | #9 |
Re: Trans options?
Thanks for the help gang. Yes, mostly looking to get some highway mileage out of the upgrade. AOD is probably the route to take.
The car is actually an Edsel (my brothers). Yes, a very rare '60 Edsel wagon, and a hole in the floor really isn't an option. To all the purist, I promise ALL changes made to the car can be easily reversed and brought back to stock. |
05-08-2010, 12:02 PM | #10 |
Re: Trans options?
Bendtsen has an AOD to Y block adapter, but they ain't cheap.
I'm just an old truck guy trapped in a hotrodder's world. |
05-08-2010, 01:47 PM | #11 |
Re: Trans options?
$850.00
05-08-2010, 02:04 PM | #12 |
Re: Trans options?
The more frugal option if your present transmission is OK is to change rear gears,since it is a 9" those are usually fairly inexpensive as the racers usually swap them out to get a stouter gear,a 3.00 is not hard to find.
05-08-2010, 08:12 PM | #13 |
Re: Trans options?
05-08-2010, 11:22 PM | #14 |
Re: Trans options?
I have a 3 speed with overdrive from a '61 that is for sale.
Aaron (510)415-1219. |
05-11-2010, 09:42 PM | #15 | |
Re: Trans options?
Lee
Salt Is Good... Mk 9:50 |
05-12-2010, 01:58 AM | #16 |
Re: Trans options?
Rumble seat? How come your location is listed as Fruitport,Mi. Did you move out of Colo.?? just curious? ken ct.
05-12-2010, 08:04 AM | #17 |
Re: Trans options?
Ken, I think this is another Rumbleseat
05-12-2010, 09:27 AM | #18 |
Re: Trans options?
I bought a C-4 adaptor from Mummert for my Y-Block FED. $500 Nice kit, had everything I needed.
05-19-2010, 12:14 PM | #19 |
Re: Trans options?
The car is actually an Edsel (my brothers). Yes, a very rare '60 Edsel wagon, and a hole in the floor really isn't an option. To all the purist, I promise ALL changes made to the car can be easily reversed and brought back to stock.[/QUOTE]
I have an AOD in my '59 Edsel, and it made a huge different to the performance of the car. Having the overdrive is awesome. Get yourself a Lokar tv cable, and you'll need to build some kind of Trans crossmember. Other than that it's easy. |
05-19-2010, 03:11 PM | #20 |
Re: Trans options?
I have an FMX behind a 292 in a 54 Sunliner A simple conversion and still a basic stock car. Don't know if this is what you are looking for but runs great in my car. Gerry
