07-06-2019, 10:06 AM | #1 |
Small Parts Spray Paint
As I am working on my A I am wondering if there is a recommended paint to use on small parts like steering and brake components, (pitman arm, Clutch and Brake Pedals etc.) I end up working on it a little at a time and when I get a couple parts cleaned up and ready for paint I don't have enough to justify getting out my gun and mixing up paint.
07-06-2019, 11:12 AM | #2 |
Re: Small Parts Spray Paint
I agree with you akersa,not worth the hassle. I have been for the past 13yrs used Rustolium spray can paint.Still a good product and comes in flat,satin and gloss.
07-06-2019, 08:28 PM | #3 |
Here is a trick I found to work well. Hook a lead from the positive pole of a car battery to the part to be painted. Hook another lead from the negative pole to the spray can. You can hold that lead on to the spray can with one of those foam insulated can holders so that the bare wire is making contact with the spray can. This will charge the spray particles and the positive charge on the part will attract the paint so there is very little overspray and you use less paint. It sounds strange but it works!
Be sure when you are done to wipe off the spray nozzle and rap the can on the bench a couple of times to settle the paint away from the spray orifice. The spray nozzle is less likely to plug up then. It works for me! |
07-06-2019, 08:35 PM | #4 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
07-06-2019, 08:45 PM | #5 |
07-07-2019, 09:56 AM | #6 |
07-07-2019, 09:59 AM | #7 |
I use Rustoleum
07-07-2019, 11:43 AM | #8 |
I use Krylon, a lot of overspray with Rustoleum...........Bob
07-07-2019, 11:46 AM | #9 |
Ditto
07-07-2019, 01:35 PM | #10 |
I have been using VHT epoxy black,comes in semi-gloss and gloss.It requires no primer as it is supposed to be self priming.I get it at Advance Auto or AutoZone.
"Never complain,never explain"... Henry Ford II |
07-07-2019, 04:25 PM | #11 |
I use Rustoleum and Valspar implement paint. The Rustoleum dries faster,but ai think the Valspar is a better paint in gloss and hardness.
John
Welcome each day |
07-08-2019, 12:07 PM | #12 |
I use Eastwoods Chassis Black. You have to use their primer but you can brush the primer and top coat on small pieces and it looks great. Just another option.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain |
07-08-2019, 10:14 PM | #13 |
Car battery. Positive lead to the part. Negative lead to the paint can. Less overspray.
07-09-2019, 05:19 AM | #14 |
Just finished a front end rebuild. Red primer then a lite sanding. Rustoleum guide coat then wait 24hrs.
Before light sanding. A few coats of rustoleum black. Very important. ..let dry for a week,don't touch and do not rush. Valspar is a good paint also. Wick |
07-09-2019, 08:25 AM | #15 |
I've used Rustoleum rattle cans with good results, however Rustoleum being oil based takes a very long time to dry completely through (beneath the surface). I've found that Krylon drys very quickly all the way through which I believe makes it less prone to chipping.
07-09-2019, 11:19 AM | #16 |
Rustoleum and other paints dries very quickly here. Just spray and leave in the sun for a few hours. Oven baked enamel. 90+ degrees, and humidity less than 10% you would be surprised as to how quickly things dry completely. Dark colors you have to be careful when you pick them up to keep from getting burned.
