01-17-2011, 12:02 PM | #1 |
Can this worm gear/sector shaft be saved?
Guys, here you can see some gauling on the sector shaft and worm gear. Must these be replaced? Can a good machine shop smooth these out? Thanks for all the input.
John Mc Crystal Lake, IL '39 1/2 Ton Pickup '56 Lincoln Capri Hardtop '77 Lincoln Town Coupe |
01-17-2011, 12:21 PM | #2 |
Re: Can this worm gear/sector shaft be saved?
Dosen't look good to me? ken ct.
01-17-2011, 12:43 PM | #3 |
Replace them both. To gaul like that, there is plenty of wear to warrent it. You will be kicking your self later if you don't.
01-17-2011, 12:44 PM | #4 |
you can get a used box with good gears cheap
01-17-2011, 01:53 PM | #5 |
Replacement is your only out. That's one of the faults of Gemmer steering gears.
01-17-2011, 02:14 PM | #6 |
01-17-2011, 02:33 PM | #7 |
John, I would not recommend using those parts in your picture. I would either try to buy some good used or go for the new. There was a recent thread here about replacing the roller sector gear. I have pressed quite a few worm gears off and on these shafts. It is a bit tricky pressing some back on but I could walk you through how I did it if you want to know.
01-17-2011, 03:36 PM | #8 |
I certainly would love to know from those that have gone before me. I have a 12 Ton press. My email is [email protected]. Thanks in advance.
01-17-2011, 07:43 PM | #9 |
Mac's has a '37-'48 worm gear for $60. They also sell the roller & pin kit for the same years for $59.75. I asked the tech about the source of these parts and he mentioned Argentina. Although I have heard some bad comments about Argentina parts, he claims to have not received any complaints about defects in these parts with over 100 of each sold last year! I am also looking into re-doing my steering box due to excessive and unresolved steering wheel play. One of the issues seems to be removing the old worm and pressing on the new one on a hollow steering shaft. I see that Bratton's offers steering worm replacement on Model A's for $67. Would they do a V8 worm and shaft? Worth asking! Let us know what you find out!
01-18-2011, 12:52 AM | #10 | |
Thanks, Neal |
01-18-2011, 01:03 AM | #11 |
Neal, Simply heat the replacement worm in oil, being careful not to start a fire! When the oil is smoking it means its hot enough, and the worm will simply drop on to the shaft. Just pay attention to the orientation; very easy to do. Hold the worm in place until it has shrunk onto the shaft. I normally just hold the shaft vertically with the worm resting on a support. Brian
01-18-2011, 02:37 PM | #12 |
Brian - Thanks for the reply...I will try the oil/heat method and see how it works out.
Neal |
01-20-2011, 10:56 PM | #13 |
I've got a new worm and roller from Mac's. Should be here for the weekend. Thanks for all the input.
01-20-2011, 11:33 PM | #14 |
John & Neal, send me a PM if you would like some details on how I have pressed these worm gears back on the steering shafts. I also use heat and chilling to reduce the press fit but do not use the hot oil method as Brian mentions.
