03-24-2019, 07:35 PM | #1 |
Fuel pump
I am in need of a low pressure 6 volt fuel pump for my Webber down draft carb set up. Any help would be appreciated.
Thanks |
03-24-2019, 08:14 PM | #2 |
Re: Fuel pump
03-24-2019, 08:15 PM | #3 |
Re: Fuel pump
Contact Arizona Model A. 480-782-0266, closed Mondays.
03-25-2019, 06:27 AM | #4 |
Re: Fuel pump
I have found that a 12 volt pump from NAPA will produce about 2-3 # pressure when connected to 6 volts. It works fine and won't over pressure the float.
I have done it many times.
03-25-2019, 06:41 AM | #5 |
Re: Fuel pump
Use a rotary pump and not one of the solenoid types. Ethanol gas destroys the vibrating types in short order.
03-26-2019, 02:39 AM | #6 |
Re: Fuel pump
03-26-2019, 02:16 PM | #7 |
Re: Fuel pump
Definitely call 'Sammy' at Arizona Model A. Ernie in Arizona
03-27-2019, 12:32 PM | #8 |
Re: Fuel pump
My rig is 12 volts. I am using a generic fuel pump I bought at O'Riley's, plus a Holley regulator set to 2.5 psi, feeding a single Stromberg 97.
