01-29-2019, 10:46 AM | #1 |
39 coupe radiator
Hi guys
I decided to get radiator rodded/cleaned professionally. In summer the car constantly runs 210 (highway or stop and go) it never boils over but I would like it at 195 or up to no more than 200. I’m runnin 170 stats. And have double check heads w infer-red and run 50/50 mix antifreeze. Any insights / tricks you and lend? I don’t think I need remove the fan ~ do I?
Thanks Andy 1952 F1 |
01-29-2019, 11:02 AM | #2 |
Re: 39 coupe radiator
It is a little easier to remove the radiator if the fan is out. Fan removal is easy 4 bolts, but you will probably need to whack a chisel into the gap between the crank and fan flanges. In any case, put a piece of cardboard between fan and radiator while maneuvering either fan or radiator out of and into the car.
01-29-2019, 11:21 AM | #3 |
Hey, Andy -
2 things.....if you can fit a piece of paneling or carpet instead of cardboard it will be that much more protection than cardboard. It takes nothing to wrinkle or pierce these radiators. The other thing is if you don't already have a guy - I used Hawthorne Industrial Radiator in Wayne. I just got the pressure clean and patch without the full rodding. Good Luck!
John Haelig Bridgewater, NJ 1939 Ford Pickup 1963 Lincoln Continental 1939 Buick |
01-29-2019, 12:46 PM | #4 |
What kind of temperature drop do you get through the radiator?
01-29-2019, 03:50 PM | #5 |
Thanks John and rest all good feedback.
Flatjack that’s a very good question and I never checked that. I’ll try as soon as weather warms a bit.
01-29-2019, 03:57 PM | #6 |
01-29-2019, 04:54 PM | #7 |
1939 Standard Coupe. Had my radiator serviced and cleaned at recent engine rebuild.
Run 180 stats. It sits on this 180 temp once system has warmed up. On very hot day running at highway speed temperature is a steady 180. Again endorse a radiator service. I now know its right and it gives peace of mind and confidence to continue driving. Phil NZ |
01-29-2019, 05:20 PM | #8 |
Seth / Phil thanks. Cause I was telling a buddy I don’t mind spending the $$ if it fixes the issue. Your words gave me the additional confidence I need.
01-30-2019, 05:20 PM | #9 |
See, andy we all agree , A good radiator cleaning should be the answer, fingers radiator does do good work ,they have been around for many years.
