Old 11-05-2018, 10:52 AM   #1
rottenron36
rottenron36's Avatar
Default red keyed 12-24 volt battery cut off switch
Will those red removable keyed battery cut off switch work on 6 volts? They a for sale everywhere. I tried to get a picture up, but no go. They are 12-24 volt with a 125 amp rating. Thanks Ron
rottenron36 is offline   Reply With Quote
Old 11-05-2018, 11:06 AM   #2
47COE
47COE's Avatar
Default Re: red keyed 12-24 volt battery cut off switch
125 amps doesn't seem like enough. It is common for the switch to have a continuous rating and an intermittent rating. See if the one you are looking at has the intermittent rating listed. As for 6 vs 12 volts, that doesn't matter. It is the higher current draw of a 6 volt starter that you need to deal with.
The one I have is 300 amps continuous, 2000 intermittent.
See, for example: https://www.summitracing.com/parts/mor-74102/overview/
47COE is offline   Reply With Quote
Old 11-05-2018, 11:07 AM   #3
19Fordy
19Fordy's Avatar
This keyed switch claims it will work on 6V.
https://www.ebay.com/itm/Keyed-Maste...gucA:rk:5:pf:0
19Fordy is online now   Reply With Quote
Old 11-05-2018, 11:51 AM   #4
Fordestes
google cole Hersee, they have some that will stand 500 plus amps I have been using them for over 25 years ,they offer the key type as well and one that will allow a new style radio to retain the settings, the c.h. cost around $30 or near that ,Flaming river offers a 1000 amp ,the price is beyond my reach and not necessary, I put them on the earth ground side whether it be plus or minus in case the cables rub and short to chasis there wont be any fire hazard . if you cant locate one you want , the next trip I take to town I will try and grab an extra then ship it to you, the price may be a little higher as everything has gotten more expensive lately.
fordestes
Fordestes is offline   Reply With Quote
Old 11-05-2018, 11:57 AM   #5
Fordestes
The one 1940 shows is the style I use ,and the price is a great deal , I didn't know Pollak offered them. certainly a great price for sure. check the amperage rating, voltage doesn't really matter ,it's the amperage that is the main concern.
fordestes
Old 11-05-2018, 12:16 PM   #6
47COE
47COE's Avatar
This has 1000 amp surge and 185 continuous. Should easily do the job.
Old 11-05-2018, 02:36 PM   #7
rottenron36
I found some more information on the red keyed switch, I was talking about, Good for up to 50 volts, 200 amps cont. and 500 amps for 5 seconds. Hope that helps. Thanks Ron
Old 11-05-2018, 04:02 PM   #8
russcc
I used those keyed red ones, I believe Hella made them, which is, or was a good name, but I found they failed under amperage. I used Cole Hersee from them on in. Never had a problem. They are no longer Made in USA, but the ones from South of the border seem fine.
russcc is offline   Reply With Quote
Old 11-05-2018, 04:27 PM   #9
Lawrie
Lawrie's Avatar
My 33 got hard to crankr one time,would always start ,but man some times it looked like it would only just turn over.
turned out to be the red plastic keyed bat isolator,]
Replaced it with a proper steel one from an industrial supplier,starts good now.
Lawrie
Lawrie is offline   Reply With Quote
Old 11-05-2018, 06:48 PM   #10
corvette8n
corvette8n's Avatar
I have one I bought for my Ford 8N but never used it, I thought it didn't look heavy duty enough. I found an NOS Cole-Hersey on fleabay and used that on my '41 Ford.
