Old 10-31-2018, 05:12 PM   #1
Heard
Heard's Avatar
Default How do I make this black again?
Paint? or something else?
Thanks,
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 10-31-2018, 05:23 PM   #2
19Fordy
19Fordy's Avatar
Default Re: How do I make this black again?
How about epoxy primer followed by black acrylic enamel.
Old 10-31-2018, 05:24 PM   #3
DavidG
DavidG's Avatar
They often will polish up nicely with some rubbing compound, but there's always the alternative of painting it.
Old 10-31-2018, 05:47 PM   #4
tubman
tubman's Avatar
Krylon makes paint specifically for plastic. I have used it and it works fine. I think that if it were mine, I'd try the rubbing compond approach "DavidG" suggested first.
Old 11-01-2018, 09:36 AM   #5
1930 coupe
I use black india ink on faded bakelite parts.
get some and try it on the back.
Make sure it is INDIA INK because only india ink will look black in the bright sunlight. Most other black inks will look purple or dark blue in the sun.
You can apply it with a Q-tip then wipe off the excess.
It will NOT have a painted look.
1930 coupe is offline   Reply With Quote
Old 11-01-2018, 09:47 AM   #6
emf
emf's Avatar
There is a product that I think Meguiars makes called Back To Black. It's similar to a polish that is used on black plastic bumpers or black surfaces to remove the chalky white residue. Worth a try...
Frank
emf is offline   Reply With Quote
Old 11-01-2018, 10:12 AM   #7
Heard
Heard's Avatar
Great ideas guys. Thanks!
I have used the india ink before on bakelite with not so great results, but it was probably user error.
Old 11-01-2018, 12:48 PM   #8
1930 coupe
Wash the part with soap and water, or alcohol using a old toothbrush to remove dirt and oil and you will have better coverage. If it is a hard shinny plastic it may not sink in very well.
Old 11-01-2018, 01:12 PM   #9
rotorwrench
rotorwrench's Avatar
Plastic oxidizes & deteriorates like most other things. Paint will actually protect the plastic. Just clean it well as has already been mentioned.
Old 11-01-2018, 02:02 PM   #10
my4dv8
What does the underside look like?
I am fairly sure even a light wet sand with 1500 paper then rubbing compound and a final glaze compound will bring it back to life.
my4dv8 is offline   Reply With Quote
Old 11-01-2018, 08:06 PM   #11
Tinker
Tinker's Avatar
They chrome plastic on new cars. Maybe you can research adding a black oxide (bluing) treatment? Maybe just a nice buffing might be good enough for application?
Old 11-02-2018, 06:28 AM   #12
Karl
Karl's Avatar
Try black shoe polish (nugget) -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 11-02-2018, 06:37 AM   #13
oldbugger
oldbugger's Avatar
SEM makes a bumper flat black that I used on my steering wheel, looks good. mho. Paul
oldbugger is offline   Reply With Quote
Old 11-02-2018, 09:11 AM   #14
Not George
Not George's Avatar
I blasted one with baking soda with a cheap HF gun. Cleaned up very nice.
Then you can do what you like.
Not George is offline   Reply With Quote
Old 11-02-2018, 10:30 AM   #15
waterboychuck
waterboychuck's Avatar
I thing you should sand it will 2000 wet and buff it out. I've attached a photo of two window frames where one was complete and the other not yet started.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 11-04-2018, 04:12 PM   #16
Heard
Heard's Avatar
Default Re: How do I make this black again? Update
Guys,
Thanks for all of the suggestions. I actually bought some of that Back to Black stuff and tried it on the back. It seemed to work OK, but then I read the fine print where it says 'Lasts for weeks'. NOT really what I was looking for.
So I decided to try just some polishing compound with a Dremel tool. You know those bars of stuff you can buy. A quick trip with the white compound and then the red rouge stuff seems to do the trick. Don't run the Dremel very fast though.
Here it is half done. Needs a bit more polishing but I like it. It doesn't look freshly painted if you know what I mean.
Old 11-04-2018, 10:39 PM   #17
RalphM
RalphM's Avatar
Nice results! That looks like it will do the trick!
RalphM is offline   Reply With Quote
Old 11-05-2018, 08:08 PM   #18
Tinker
Tinker's Avatar
Nice work! Looks great.
Old 11-08-2018, 02:46 AM   #19
my4dv8
Nice work Heard. That’s what i thought would happen but had not been smart enough to think Dremel. No braid aid fixes of goop. Persistence will pay of in a very long term fix for you.
