08-24-2018, 08:40 AM | #1 |
19 inch wheels and tires
I have 5 nice 19 inch wheels and firestone tires about 2 years old tires lug nuts those little shim things hub caps the works. Problem I don’t know what to charge for them. Any help from the knowlegable people on here would be appreciated. Thanks
08-24-2018, 08:51 AM | #2 | |
Re: 19 inch wheels and tires
I think posting pictures would help get a better idea of the price you could ask.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
08-24-2018, 09:02 AM | #3 |
I would say you should charge $100 a piece, more or less considering condition vs new.
08-24-2018, 09:04 AM | #4 |
There black wall tires ris are green apple i believe that’s the color they called them. Yeah i tried posting pics on here ain’t smart enough i guess.
08-24-2018, 01:27 PM | #5 |
You say you have "those little shim things" which to me indicates you have the washers used under the lug nuts when the openings in the wheels are wallowed out. This makes the wheels low buck value if that is the reason the washers were used. I hope that is not the case, but it is a red flag.
08-24-2018, 02:42 PM | #6 |
08-24-2018, 05:22 PM | #7 |
Wheel nuts get loose and wollows out the holes. Then the taper on the nut goes through the hole and bottoms out on the drum without applying force to the wheel. Washer helps but does not self center as well.
08-24-2018, 06:22 PM | #8 |
I've taken to using the lug washers on all A's.They really help as far as chipping paint,and if you have a bad hole or it makes your wheels usable.I picked up five powdercoated wheels years ago,the guy had bought them at flea markets and had them done.He didn't know what he was looking at and actually bought five smooth,pit free wheels with bad lug holes.He was kind of heartbroken,with what he spent on them,but I put them on a car and they've been on the road for more than 20 years.The owner of the car knows all about them,he says they ain't bothered yet.
08-24-2018, 07:41 PM | #9 |
That's a GREAT DEAL for someone who needs them & He's out there somewhere & would pay you a fair price, for them!
Bill Positivethinker
08-24-2018, 07:44 PM | #10 |
I was talking to some of the a guys at the local car show and they said they use the washers so you don’t get the wallowing i looked at there cars and they all had them on.
08-24-2018, 09:21 PM | #11 |
Would help if you said where you are located- or better yet where the wheels are. Local prices vary.
Brian SATX |
08-24-2018, 09:56 PM | #12 |
Yes very sorry for that i live in whitehouse ohio which is a burb of Toledo oh
08-25-2018, 10:39 AM | #13 |
Are ALL the houses WHITE, in Whitehouse, Ohio?
Bill Wondering
08-25-2018, 01:41 PM | #14 | |
A couple of years ago I paid $600 for a brand new set of white walls mounted on good straight rims. Figured I would have had to pay $200-$300 more from a supplier just for the tires, plus I got some good rims. |
08-25-2018, 04:29 PM | #15 |
Yes I’m thinking 600.00 should be fair. If somebody wants to get them.
08-27-2018, 08:03 PM | #16 |
Depends on the color!
08-29-2018, 07:35 AM | #17 |
Model a Steve, really the color matters? I think your kidding but they are green.
08-30-2018, 08:03 PM | #18 |
PM sent
08-31-2018, 12:56 PM | #19 |
