07-27-2018, 07:52 PM | #1 |
radiator filters
I am about to put new radiators in each of my 28's. The block is thought to be reasonably clean however I don't want trash entering these new investments.
What are your thoughts people on radiator filters. Thankyou in anticipation for your responses. g
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
07-27-2018, 09:01 PM | #2 |
Re: radiator filters
Great idea, clean often though
07-27-2018, 09:10 PM | #3 |
Use a nylon stocking. Cut the bottom part of the leg off and place the open end over the upper water neck inside the hose, and the toe about equal to the top part of the upper hose. Been using them for years.
07-28-2018, 01:11 AM | #4 |
This is what I got when I picked up my recored radiator yesterday.
07-28-2018, 03:37 AM | #5 |
I bought this at Amazon and installed two screens and gave 1 to my wife. They come 2 per pack.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
07-28-2018, 11:54 AM | #6 |
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-21-2018, 04:23 AM | #7 |
thankyou all for your input. I used the Gano type and in the first run of about 900 miles I pulled a good tablespoon from the filter. This was otherwise going to lodge in my new radiators. I liked the tea strainer too but was unable to acquire a two inch one locally.
thanks again all. gary
10-21-2018, 04:24 AM | #8 |
Yes I liked that idea too. gary
10-21-2018, 09:56 AM | #9 |
Just be very careful with a filter on the cooling system.
Please remember, Model A’s are “syphon flow” aided by a water pump for higher speed assistance. Flow is about 36 to 38 gpm. Modern cars are 100 gpm plus. If your filter starts to restrict flow, you could be in trouble fast. If you have completely cleaned out you block? That along with your new radiator could be all you need. Enjoy. |
10-21-2018, 10:06 AM | #10 |
hcc
10-21-2018, 10:25 AM | #11 |
hcc
10-22-2018, 11:13 AM | #12 | |
10-22-2018, 11:16 AM | #13 |
10-22-2018, 12:00 PM | #14 |
May Be His Initials.?
10-22-2018, 12:21 PM | #15 |
Here are a couple of additional threads, If you do a search, probably a lot more threads.
https://www.fordbarn.com/forum/showt...ighlight=tefba https://www.fordbarn.com/forum/showt...ighlight=tefba |
10-22-2018, 04:32 PM | #16 |
yeh, probably. Maybe he's like me and finds difficulty in understanding just how to use these forum programs.? Do have another go hcc. cheers, gary
08-18-2019, 09:42 PM | #17 | |
08-18-2019, 11:43 PM | #18 |
Like he said, check it often!!! Once all clear, you can remove it.
08-19-2019, 09:47 AM | #19 |
Search Tefba,a filter made in Australia and on Ebay sometime.
"Never complain,never explain"... Henry Ford II |
08-20-2019, 09:08 AM | #20 |
A review of mine on the Tefba filter.
https://www.fordbarn.com/forum/showt...ighlight=Tefba Addition info/update - I called V12 multiple times about the magnet, was promised it, and never received it. Have since converted to the Gano. I just feel it is handier to check it visually every time I am under the hood. |
