03-16-2018, 09:54 AM | #1 |
Just what is the difference in the "A" & "B" 4 cylinder Ford engine?
Being new to original 4 cylinder Ford engines and trying to educate myself share with me what you have learned over the years.
This is my introduction to the 4 in a row. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell Last edited by HOTRODPRIMER; 03-16-2018 at 09:59 AM. |
03-16-2018, 10:22 AM | #2 |
Re: Just what is the difference in the "A" & "B" 4 cylinder Ford engine?
HRP,
the best advise I can give you is to read and think thru what you will hear. in a nut shell, "B" motor has larger journals in rotating assembly than the "A". Fuel pump added, cam marginally better, chamber difference in head are just some details. Both models are prone to cracking if not properly cared for. John
As Carroll Smith wrote; All Failures are Human in Origin. |
03-16-2018, 10:31 AM | #3 |
Go to Vince's site and scroll down to Engine Mechanical Assembly, a
lot of information on the two engines. http://www.fordgarage.com/ Bob |
03-16-2018, 01:04 PM | #4 |
25% more horsepower in the B.
03-16-2018, 01:38 PM | #5 | |
Ford built the B to improve on the A. Just like Ford built the flathead V8 to improve. Easy to digest, eh ? So, logically the B is a better engine for reasons stated. More reasons added, is that Ford added better oiling to B for mains. Ford also added a fuel pump with improved performance under most conditions. Going from a '32 B engine in you '32 car , to an A engine would be regressive, IMO, unless you got a hot A engine over a stock B engine. Oh, and red paint adds mph and hp to both A/B !! Last edited by hardtimes; 03-17-2018 at 01:25 PM. Reason: .......... |
03-16-2018, 06:52 PM | #6 |
03-16-2018, 08:42 PM | #7 |
Your lower water pipe needs to be turned end for end.
03-16-2018, 09:34 PM | #8 |
Can you elaborate? HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell |
03-17-2018, 01:03 AM | #9 |
Loosen the two clamps, remove the steel pipe and turn it end for end. It's installed backwards now. It'll fit better, and the drain cock will be at the lowest spot. OK, I was just informed you have a 32, not a Model A, so this pipe isn't correct for your car, and the 32 pipe isn't reproduced. Vince has the correct pipe though. Here's a like to Vince Falter's website. http://www.fordgarage.com/ Last edited by Tom Wesenberg; 03-17-2018 at 03:30 AM. |
03-17-2018, 03:32 AM | #10 |
Normally what Tom initially said above would be correct, except that it appears that your's has been modified for a heater hose. What does the other side of the engine look like? Definitely not stock carburetor. Also noticed that your vibration damper is not attached to the rear of engine.
03-17-2018, 05:20 AM | #11 |
What is this, so called, "vibration dampener"????
Bill Neverheardofit
03-17-2018, 08:11 AM | #12 |
Looks attached to me.
03-17-2018, 11:15 AM | #13 |
03-17-2018, 01:20 PM | #14 | |
Hey Bill, If you look closely...as old eyes like mine can't do, you will notice that that is not a model a firewall (IMV). Ford , most likely, thought that the '32 engine would 'feel' like it was operating more smoothly , if it was not transmitting engine vibes thru the frame / vehicle...ergo he added (on firewall) vibration dampener. Someone more familiar and/or owning a '32 car can correct or add to this info if necessary, as I'm not in the class ($ wise) to own a '32, but like many admire Fords change of styling from that of Model A. BTW...that's if behind the red colored coil cover. Also, evidently, pic shows 3 bolt waterpump B head, but I'm not convinced that this is not an A block. That does not look like a B oil tube(?). HRP...show other side of block. I think that it is A blk shown (in a '32) and that is why he is asking about A vs B question..no ?? Last edited by hardtimes; 03-17-2018 at 01:34 PM. Reason: ............. |
03-17-2018, 03:19 PM | #15 |
Should post this on the Early V8 (1932 to 1953) forum also - there's several experts on the Model B 4 cylinder engines and the differences there.
03-17-2018, 07:13 PM | #16 |
There appears to be a bracket from the dampener to the top two bell housing bolts as far as I can tell. The breather is a model B.
03-17-2018, 08:00 PM | #17 |
03-17-2018, 09:23 PM | #18 |
Sorry. The other one.
11-24-2019, 07:00 PM | #19 |
What is this dampener you are talking about? I've never heard of that. Did you notice that the band is coming off of the end of the starter on the red engine?
11-24-2019, 07:26 PM | #20 | |
It is hard to tell from the camera angle but that could be an early B oil tube that was the same diameter as the A but longer. Note that the engine has the rectangular mounting pad for the never adopted vacuum assisted clutch. This would point to it being an early engine. What is the serial number on the flywheel housing and on the frame? The attached photos show he rectangular boss on the block, the vibration damper installed and the oil fill pipe on a Model A (it is hard to tell from the picture but it is shorter). Charlie Stephens Last edited by Charlie Stephens; 11-24-2019 at 08:06 PM. |
