01-22-2018, 01:15 PM | #1 |
fe motors
I'm looking at a 1960 ford thunderbird the motor is stuck don't know how bad yet but will any fe motor fit it
I remember back a long time ago I tried to put a 352 into a 1974 ford truck and the motor mount would not fit been along time I bee around one I thought the newer one had more spots for the motor mounts thanks |
01-22-2018, 03:03 PM | #2 | |
Re: fe motors
01-22-2018, 03:25 PM | #3 |
Re: fe motors
ok thanks I thought that but wanted to make sure
so what's is it between the gold paint and blue paint on the engine |
01-22-2018, 05:09 PM | #4 |
Re: fe motors
corporate blue came out in 1966. Before that most were black, some gold and some red.
01-22-2018, 05:18 PM | #5 |
Re: fe motors
I put a 332 into a 69 highboy once. I just made some plates from 1/2 stock, drilled the holes for the mounts and for the block. I did have to slot the motor mount holes in the towers a little to get the mount studs through. The engine will set a bit higher but it never seemed to be a problem
01-22-2018, 10:02 PM | #6 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Re: fe motors
01-22-2018, 11:08 PM | #7 |
Re: fe motors
ok thanks these are blue
01-23-2018, 10:51 AM | #8 | |
Re: fe motors
The later blocks have 4, with the added bosses positioned forward and wider apart than the original bosses. |
