01-20-2018, 04:59 PM | #1 |
Turn signals
I just bought a 1930 model a and I am changing it over to a 12 volt, My question is do I have to change my 6 volt controller to a 12 volt controller or can I just change the flasher and keep the same controller. Sorry for the dump question but I am new at this.
01-20-2018, 05:05 PM | #2 |
Re: Turn signals
Why do you wan't to change to 12 volts?
01-20-2018, 05:09 PM | #3 |
Re: Turn signals
There is no need to change to 12v.
01-20-2018, 05:34 PM | #4 |
Re: Turn signals
And heeere we go!
01-20-2018, 06:14 PM | #5 |
Re: Turn signals
I wouldn't change to 12volt but, if you do just change the bulbs and flasher the switch is just a switch.
01-21-2018, 12:24 AM | #6 |
Re: Turn signals
01-21-2018, 12:27 AM | #7 | |
Re: Turn signals
I have converted to 12 volts and glad I did. I have been in some pretty out of the way places when I needed an ignition coil, even a globe. Not many places sell 6 volt component now but 12 - no problem.
01-21-2018, 12:52 AM | #8 | |
Re: Turn signals
And are you sure that "in the pretty out of the way places" you will find parts ? (btw I don't now what a 'globe' is) |
01-21-2018, 12:55 AM | #9 |
Re: Turn signals
Are you referring to the turn signal switch on the column? If so, probably should be OK with just the flasher change. We use the 3 prong type . If there is a bulb in the flasher stalk, that may need to be changed. In ours was a 1 watt mini bulb..
01-21-2018, 02:04 AM | #10 |
Re: Turn signals
Down under I see the flashlight called a torch, and headlight or light bulb called a globe.
01-21-2018, 10:30 AM | #11 | |
Re: Turn signals
01-23-2018, 11:44 AM | #12 |
Re: Turn signals
[IMG][/IMG]You won’t need to change the switch itself just the signal stat and bulbs. I kept my 31 Tudor in its original 6 volt system. I don’t care for most of the current aftermarket turn signal systems that are available. I made my own 6 volt system using a 6 volt signal stat from an old Kawasaki motorcycle and switches that I believe are originally used in MG cars. The mount for switches is an aftermarket gauge holder for the Model A. [IMG][/IMG]
01-23-2018, 12:39 PM | #13 |
Re: Turn signals
If you have an LED turn signal system you should not have to change anything
01-23-2018, 03:07 PM | #14 | |
Re: Turn signals
I just don't like having that big Signal Stat switch on the steering column. I used a SPDT switch hidden under the dash rail. Last edited by Y-Blockhead; 01-23-2018 at 03:18 PM. |
01-23-2018, 04:07 PM | #15 |
Re: Turn signals
That's fine but when the spare coil fails (and it did), you need to be able to buy another. So many of the parts we buy these days are soooo crappy that a spare might not be enough. That situation was the exception, I agree but whatever, it is much easier to buy 12 volt components than 6 volt and that is the point of what I was saying.
01-24-2018, 12:15 AM | #16 | |
Re: Turn signals
Back when I was into Corvairs I would drive my favorite Corsa all over the place. It had a coil, points, condenser, etc. and I carried no spares. Not sure how we got here from turn signals tho, haha. |
01-24-2018, 08:24 AM | #17 | |
Re: Turn signals
The switch on the left operates the turn signals. The switch on the right is for my cowl lights and a future accessory. When I started to research the turn signal systems that are currently available, I couldn’t find anything that I liked. I just didn’t like having a box on the dash, micro switch on the shifter or the 50ish looking turn signal stem on the steering column. I wanted something that looked period correct in the car without drilling any new holes. A lot of searching on E-Bay I found the switches in the UK. I made an insert for the gauge holder on the column and added a fuse block and signal stat off an old motorcycle. The whole system can be removed with no trace of ever having been there. It would have been cheaper to go with what’s available on the market but I really like this set up better. |
01-24-2018, 10:06 AM | #18 |
Re: Turn signals
01-24-2018, 10:22 AM | #19 | |
Re: Turn signals
Bill Okie
