12-31-2017, 09:14 AM | #1 |
Winfield Valve Cover
Does anyone out there know what a excellent condition Winfield valve cover sells for.
12-31-2017, 11:27 AM | #2 |
Re: Winfield Valve Cover
R U buying or selling??
Paul in CT |
12-31-2017, 01:27 PM | #3 |
12-31-2017, 02:02 PM | #4 |
New ones are around $100 I believe. So original $125-$150 maybe?
Cowtown A's |
12-31-2017, 02:30 PM | #5 |
Selling
12-31-2017, 04:28 PM | #6 |
12-31-2017, 06:24 PM | #7 |
How can a valve cover be improved, other than looks?
John |
12-31-2017, 10:06 PM | #8 |
With proper design they can strengthen the block the same way a crank girdle does.
A common improvement for vintage circle track engines. And it is big fun if the owner will go along with it, to machine a name like Caterpillar in the cover. |
12-31-2017, 10:18 PM | #9 |
Sold mine for $35.
in 1963 |
01-01-2018, 05:04 PM | #10 | |
Do you make aluminum side covers for A/B (flathead and/or OHV style) with name ? If so, script or block writing ?? |
01-01-2018, 05:13 PM | #11 |
Hey John,
I go along with the idea/statement of Pete regarding 'strengthening'/thickness of material. For example, I have a really thick aluminum finned side plate for OHV head use. I think that an old timer (machinist?) did a one off to his liking....and mine too. Additionally, I'd recommend that , if finned, areas where you would drill/tap for oil fittings....be made flat and clear of any fins made. One more 'improvement' IMO, would to make a side plate with an oil filter screw on capability. I have one on a B engine and it is really convenient to undo a VERTICAL filter without spilling a drop. Only one I've seen like this one. Last edited by hardtimes; 01-01-2018 at 05:14 PM. Reason: ............. |
