12-28-2017, 01:03 AM | #1 |
Ultrasound cleaners
Ultrasound cleaners have any of you used these for carburetor?
12-28-2017, 04:34 AM | #2 | |
Re: Ultrasound cleaners
Using a suitable size cleaner that will accept the carburetor/s to be cleaned looks to have promising results. Some Youtube links----- https://www.youtube.com/watch?v=rRksbn8T-qU https://www.youtube.com/watch?v=-7aLziTU-eo https://www.youtube.com/watch?v=fVG-mmXE5Kk
12-28-2017, 07:40 AM | #3 |
Yes I have one and use it for carbs. I use simple green in it and have had very good results. I dunked the intake and heads from the flathead in it and had some good results on them also. I have a Kendal unit with mechanical switches instead of electronic board. I feel like I got my money's worth out of it.
12-28-2017, 08:31 AM | #4 |
I'm very happy with my Ultra Sonic. If possible get yours with heat.....mine goes up to
185. Charlie ny |
12-28-2017, 08:33 AM | #5 |
I have one of those small table top unit from Harbor Freight. It works well. Didn't really get the outside clean, but I impressed with the gunk that came out from inside of the unit. I cleaned Strombergs and newer motorcycle carbs with it.
12-28-2017, 10:19 AM | #6 |
12-28-2017, 10:39 AM | #7 |
I bought one from HF specifically for cleaning out a Vespa carb. It worked perfectly.
Just make sure the reservoir is big enough for whatever carb you intend to put in it.
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget |
12-28-2017, 11:40 AM | #8 |
I use a small ultra sonic for small parts etc and use water and dawn dishwashing soap , have used it for years......
12-28-2017, 05:11 PM | #9 |
I have a 26 quart, yes 26 quart ultrasonic I would sell that works. Its an L&R brand no heat. 200$, but its pick up only. damn thing is big and heavy.
12-29-2017, 03:30 PM | #10 |
I have a small unit I use for locks, handles etc.
I use simple green for some stuff. For rust removal I use EvapoRust on the high heat setting. The results are amazing ! EvapoRust will "eat" pot metal....... soooo..... pay attention and check the parts often.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
12-29-2017, 03:39 PM | #11 |
I use my HF one all the time. I was just cleaning transmission parts with it earlier today. Any small parts that need cleaning go in it. I have rebuilt carbs with it and it does great. Simple green and some water usually works fine.
Thanks, —louis |
12-30-2017, 03:49 AM | #12 |
Brilliant results on Model B cast iron carburettor
