08-25-2017, 11:24 AM | #1 |
vacuum wipers
hi, who fixes vacuum wipers? thanx
08-25-2017, 11:31 AM | #2 |
Re: vacuum wipers
Easy answer check the link at the top of the page and you will find 5 or six names and numbers.
Oklahoma City Model A Restorers Group. |
08-25-2017, 11:58 AM | #3 |
Re: vacuum wipers
Have you tried sucking up some MMO or other light oil into the motor? Somewhere someone has a how to clip on servicing the motor! :-( CRS
08-25-2017, 01:22 PM | #4 |
Re: vacuum wipers
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
08-25-2017, 01:55 PM | #5 | |
Re: vacuum wipers
"If you have not done a jump from a CH47 Chinook while hovering ... Check with someone who has done it and survived" 1968 at AnKhe Vietnam. The 173rd Airborne guys on base had to make a jump to keep their Jump Pay. Usually they asked the Air Force for transport. But the Air Force said that they were too busy. So they asked The First Cav for rides in a CH47 Chinook. The good thing was that the Jump Master was watching the first 10 guys closely as they jumped while hovering and saw that 5 or 6 of the chutes partially collapsed soon after they popped their chutes. Somebody had forgotten to tell them about the Rotor backwash which collapsed the chutes. These 6 guys re-qualified but the Quartermaster had to issue 6 new pairs of shorts! A couple were hurt but no KIAs. |
08-25-2017, 03:49 PM | #6 |
Re: vacuum wipers
Chief sed, "I want to go EASY"----"How do you want to go, Chief"---"Like, go to bed some night & wake up DAID"! Bill Coward
08-25-2017, 04:39 PM | #7 |
Re: vacuum wipers
Ford-Barn member grj Gary Johnson restores and sells vacuum wipers. He has one for sale in the swap meet page. Here is a link to his ad. https://www.fordbarn.com/forum/showthread.php?t=226887 Last edited by Don Turley; 08-28-2017 at 08:49 PM. Reason: additional information |
08-25-2017, 08:48 PM | #8 |
Re: vacuum wipers
Two things...
First, I was Air Force. If there is nothing wrong with the aircraft we don't jump out. Second, I had my wiper motor done by Robert Ficken. He did a great job. It was quite a few years ago, so I don't recall what it cost, but I remember that I thought it was reasonable at the time. http://www.wiperman.com/ Good luck, Ken
Style beats speed any day, and with a lot fewer tickets. |
08-26-2017, 09:38 AM | #9 |
Re: vacuum wipers
Ditto # 8
08-26-2017, 07:55 PM | #10 |
Re: vacuum wipers
I faked the one on my 31 sport coupe. I painted it semi gloss black very nicely, hooked up a short piece of hose thru the windshield frame, and put my Rainex under the seat.
08-27-2017, 11:21 AM | #11 |
Re: vacuum wipers
IF his name was FLICKEN, it would sound like the NOISES a wiper makes--LOL
Bill Sickman
08-27-2017, 03:02 PM | #12 |
Re: vacuum wipers
I was in the USAF as well, AS a Mechanic I tried to make sure no one had to jump out. I worked on both Jets and Piston engine aircraft.
08-27-2017, 07:39 PM | #13 | |
Re: vacuum wipers
Next door neighbor worked on the Flight Line @ the Air Guard. When I told him about the Roto-Rooter they used to clean out my PIPES, he sed, "Sounds like the one we use on the F-15s, to clean the IGNITER TUBE! Bill Pumpingwell
08-27-2017, 11:13 PM | #14 |
Re: vacuum wipers
John Holland out t in Ohio..
Good enough.. Isn't. |
