06-05-2017, 10:00 AM | #1 |
Model A Engine Numbee
My friend is doing a frame off restoration and has a unique engine number..."AX 3,4xx,xxx". The number on the block matches the number stamped on the chassis. Any info about "AX" would be much appreciated.
06-05-2017, 02:55 PM | #2 |
Re: Model A Engine Numbee
Here is what I could find quickly:
"Four experimental "AX" Prefix Engines, May 12-13, 1931" http://www.fordgarage.com/pages/ABenginenumbers.htm#C1
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
06-05-2017, 05:16 PM | #3 |
Thanks for the prompt reply.
The production date for the AX 3,4xx,xxx is May 15,1930 - so apparently there may have been earlier experimental engines placed into service and data not captured. This is from a 1930 Tudor. |
06-05-2017, 06:30 PM | #4 |
Could you be reading the wrong date on the car, then it fits exactly.
06-09-2017, 01:04 PM | #5 |
The engine number falls within the May 15 1930 daily production chart.
06-09-2017, 01:09 PM | #6 |
Charlie Stephens |
