05-13-2017, 06:35 PM | #1 |
Halibrand Faux quick change
Anyone know where I might find or the availability of the Halibrand case that uses the stock differential components?
Thanks, Chris |
05-13-2017, 07:21 PM | #2 |
Re: Halibrand Faux quick change
I think there was a thread on the HAMB. It was called a no-change rear end. I remember them being really expensive. I would just paint a steel one with aluminum paint.
The aluminum and mag center sections have a flaw in that the materials are much more flexible than the steel. This lets the mesh get wider and often knocking out the pinion support web. |
05-13-2017, 08:31 PM | #3 |
Not totally sure what you are referring to, the Halibrand V8 center section uses most of the original differential. The new parts are shown for a Hot Rod Works center section (There are additional parts and modifications, but these are the basic parts).
If you want a total fake quick change lookalike use one of the Speedway bolt on units. Last edited by JSeery; 05-13-2017 at 08:43 PM. |
05-13-2017, 08:53 PM | #4 |
Wilson Welding used to make a QC that was built up using the original steel rear end. I don't see it on their web site anymore.
https://www.jalopyjournal.com/forum/...ine-up.144200/ |
05-13-2017, 11:20 PM | #5 |
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
05-14-2017, 05:05 AM | #6 |
Thanks |
05-14-2017, 05:47 AM | #7 |
Vern Tardell referred to the original Halibrand "dummy" case, with a great photo on page 54 of "How to build a Traditional Ford Hot Rod."
05-14-2017, 05:51 AM | #8 |
05-14-2017, 07:09 AM | #9 |
Dick Spadaro once offered a V-8 QC center section in open or closed drive that was made for him by Winters. The cost was about the same as Don Orosco's dummy aluminum banjo housing mentioned above. I have one of Spadaro's closed drive QC's in a '35 tudor sedan.
It looks like the Speedway fake bolt on QC might be your lowest cost option.
05-14-2017, 11:53 AM | #10 |
Thanks John,
I'm exploring options for that '33 pickup. I have it all blown apart. Still need to disassemble the rearend to see what kind of shape it's in after I borrow a spring spreader and hub puller... 3 speed trans looks good internally. Wondering how everything will hold up to that hot flathead. Rear is a 4:11 going by the stamp anyway. Can always change it after I guess. |
05-14-2017, 12:28 PM | #11 |
If you can weld and all you want is a dummy for the looks. Get a cover plate and fab the rest up.spray paint it silver
05-14-2017, 12:59 PM | #12 | |
05-14-2017, 01:09 PM | #13 |
I ran cross this add the other day;
https://seattle.craigslist.org/see/pts/6089017102.html |
05-14-2017, 01:44 PM | #14 |
That's a good price if it is a good unit.
05-14-2017, 02:03 PM | #15 | |
05-14-2017, 06:27 PM | #16 |
I had one of those back in the 60's. Didn't end up using it and when I moved scrapped it. Who knew??
Paul in CT |
05-14-2017, 06:44 PM | #17 |
I have a N.O.S. magnesium Halibrand no change H201A center section, if your interested.
Tom |
05-14-2017, 08:21 PM | #18 | |
I'm just going for the look of the quick change gear box on back of th banjo for now I guess. The fake bolt on from speedway looks decent. These are interesting units though. |
05-14-2017, 08:31 PM | #19 |
There's a great deal on wooden cellphones...
www.slavetofashion.com
05-14-2017, 09:46 PM | #20 |
No. I designed and built a special rear cross member that accepts a Model A rear spring
