05-12-2017, 07:34 PM | #1 |
Are 32 steering links the same size as 34????
Hello I'm trying to figure out if a 32 steering link
"From spindle to spindle" are the same size as a 34??? Not the drag link from pitman arm. Thank you. |
05-12-2017, 07:57 PM | #2 |
Re: Are 32 steering links the same size as 34????
Well, I can help you with the name, but that is about it! Tie-rod
05-12-2017, 08:05 PM | #3 |
Those are on each end. LoL.
05-12-2017, 08:13 PM | #4 |
Actually they're tie rods ends and the tie rod is the center section.
As for the answer to the question, the tie rod and tie rod ends are the same '32-'34, unless you want to get really technical and acknowledge the difference between '32 tie rod end grease fittings and the later tie rod end grease fittings. |
05-12-2017, 08:31 PM | #5 |
Well, if you want the parts manual name, it's Spindle Connecting Rod & End, Spindle Connecting Rod. But never heard these terms used. All I've ever heard is Tie-Rod and Tie-Rod Ends.
05-12-2017, 09:47 PM | #6 |
