05-11-2017, 08:06 PM | #1 |
Helmet Dist setup
is there a good online source for info on setting up and installing a helmet distributor? Have a 59A that i would like to fire and it has has a Helmet for some reason
i have no experience with that hunk of iron. |
05-11-2017, 08:35 PM | #2 |
Re: Helmet Dist setup
This may help: http://www.vanpeltsales.com/FH_web/f...str-timing.htm
05-11-2017, 08:37 PM | #3 |
it is aluminum. is there an "extra" spacer between the cam cover and the distributor?
05-11-2017, 08:38 PM | #4 |
There's this info @ vanpelts But you might want to have it gone through @ Bubba's.
Installation is pretty easy, just make certain the key is aligned properly before you tighten or else you'll break off one of the tabs and that in no-bueno. |
05-12-2017, 04:54 AM | #5 |
