03-11-2017, 06:58 PM | #1 |
power brakes
I installed a speedway brake conversion and power booster to my 62, f100, with 292. Now I can't remove valve cover from driver side. What are my options now? Ditch power brake, or is there another solution? Yep, I know, I should have thought of that sooner. Bob
03-11-2017, 09:28 PM | #2 |
Re: power brakes
You're not the first one or the last one with that problem on many different vehicles. A picture would help, but sometimes a smaller diameter double diaphragm booster will provide enough assist and give some clearance. Put up some pictures with a tape measure along side, someone here will probably have the answer without starting all over.
03-12-2017, 06:19 AM | #3 | |
Re: power brakes
I fitted a 7" dual diaphragm booster with a corvette master cylinder. I used a set of 57 Chev booster brackets which kicked the booster up at a bit of an angle which provides adequate clearance of the rocker covers.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
03-12-2017, 06:26 AM | #4 | |
Re: power brakes
The firewall brackets in this kit are the ones I used.
http://www.ebay.com/itm/9-Zinc-Power...ke%3AChevrolet
03-12-2017, 09:05 AM | #5 |
Re: power brakes
I have a 56 merc I would like to install power brakes, any recommendations on which to buy
03-12-2017, 10:26 AM | #6 |
Re: power brakes
